驰为 CHUWIV88 3G - MT6589 7,9" XGA 3G 1GB Ram 4GB Rom 5000mah OTG GPS Alu
J
johndebur
Tablet mit Telefonfunktion und 7,9" XGA ( 1024 * 768 ) Display . ( Chuwi V88 3G )
Das tablet soll angeblich 799 yuans kosten ( ca 100€ )
Hersteller: http://www.chuwi.com/
http://detail.zol.com.cn/tablepc/index359600.shtml
搭载MT6589四核方案 驰为将推V88 3G通话平板 mtksj
Chi equipped MT6589 four nuclear program calls for the push V88 3G Tablet
3G version also retains the overall appearance of a large portion of the first two versions of the style, slightly different details, such as the design of the upper back, another key part is not the same. Chi V88 3G phone keys more biased in favor of the layout, power button, headphone jack placed on top of the fuselage, USB interface is located on the bottom, V88 and V88S focus will be placed on the bottom of the interface. Furthermore although the three dimensions are 7.9 inches screen, but V88 3G thicker, the whole size of about 201 * 138 * 7.2mm, used after the shell seems alloy.
3G version of the core hardware is not the same size as most similar programs for the MT8389, but chose phones used MT6589, clocked at 1.2GHz, built-in 1G RAM (DDR2) +4 G ROM memory, support 32G expansion. 7.9 inches IPS screen resolution is still 1024 * 768, with former 2000000 + rear 5MP dual camera, battery capacity of 5000 mA, Android 4.2 version of the system. Chi V88 3G version will support 3G Internet access as well as calls, unfortunately did not earpiece design, in addition OTG, Bluetooth 4.0, GPS, WIFI and other functions can support it.
V88 and V88S both prices are 799 yuan or so, taking the cost-effective route, although the added calling features, but the price is said to V88 3G version is equally close to the people, it may still be thousand dollars less.
http://detail.zol.com.cn/360/359600/param.shtml
Chi V88 3G Specification
Switch to the traditional form edition
Basic parameters
  • Availability: August 2013
  • Product Positioning: Entertainment Tablet PC , Mobile Phone Tablet
  • Operating system: Android4.2
CPU / GPU
  • Processor Architecture: ARM architecture
  • Processor Model: MTK6589 ARM Cortex-A9
  • Processor frequency: 1.2GHz
  • Processor Core: Quad-core
  • Graphics Core: Quad Core
Storage Devices
  • System Memory: 1GB
  • Storage Capacity: 4GB
  • Storage media: Flash flash
  • Storage Expansion: Support Micro SD (TF) card, maximum support 32GB
Display
  • Screen Size: 7.9 inches
  • Screen resolution: 1024x768
  • Screen Description: capacitive touch screen , multi-touch screen
  • Pointing device: Touch Screen
  • Screen Features: Five-point touch screen
  • Support Language: Support multi-language
Fi
  • WiFi: Support 802.11b/g/n wireless protocol
  • Network mode: China Unicom 3G (WCDMA)
  • Bluetooth function: support Bluetooth 4.0 module
Multimedia features
  • Sound system: fidelity dual speakers
  • Video Player: Support 1080P video playback
  • Camera: dual cameras (front: 200 million pixels, rear: 500 million pixels)
  • Camera features: auto focus
  • Video recording: Support 1080P video recording
  • Flash: Support Flash
Format Support
  • Audio format: MP3, WMA, OGG, FLAC, WAV, APE and other formats
  • Video format: Support WMV, H.264, AVI, RMVB, FLV, DAT, MPEG and other formats
  • Picture format: support JPG, BMP, GIF, PNG format
  • Text format: TXT, PDF, DOC, FD2, EPUB, HTML and other formats
Key / Interface
  • Audio Interface: 3.5mm headphone jack
  • Other interfaces: power interface, memory card interface
  • Function keys: switch button, volume buttons
Power Parameters
  • Battery Type: Lithium-polymer battery , 5000 mA
  • Life time: about 8 hours, the specific time depending on use environment of the
  • Power Adapter: DC (5V, 2A) Adaptive AC power supply
Function parameters
  • GPS Navigation: Built-in GPS navigation
  • Built-in sensor: Intelligent gravity sensor , magnetic sensor
  • Communication: Support call function
  • Features: FM radio function
  • Basic application: Calendar function
Appearance parameters
  • Product size: 201 × 138 × 7.2mm
  • Product weight: 310g
  • Housing material: aluminum-magnesium alloy
  • Case Color: Silver
Tablet PC Accessories
  • Packing list: Tablet PC host x1
    Data cable x1
    Headphone x1
    Manual x1
    Warranty card x1
    Certificate x1
cliffgull24
