[SOLVED] Problem Install CWM GT-N7102
leonard9500
Hi community! I'm having troubles to install the CWM on my N7102. I've already had troubles to root the device, I tried with a lot of tools like SuperOneClic, MTK Root All, MTK Droid Tools, and with different scripts, but finally I could root it with a chinesse tool called ZhuoDaShi.
Now I'm trying to install the CWM but I'm not succeeding. I tried to flash the recovery.img that @tommy0815 put in the post http://chinamobiles.org/showthread.php?34423-I-need-CWM-For-GT-N7102-MTK6577 , but I'm having troubles with the SP Flash Tool. I tried to flash it with three different versions of the SP Tool, v2.1140.0, v3.1304.0.119, v3.1224.01 but I was getting the error 8038 with all that versions.
I also tried with the Odin tool, but It doesn't detect the phone. I tried with some scripts too, like flashrecovery, cwm5ics.
I really don't know what I'm doing wrong. Any ideas?. Thank you in advance.
P/D: This is my device:
leonard9500
Thank you for your reply @OraChinaMobiles!, I've made the change in the scatterfile but I'm getting the same error as always:
leonard9500
This is the scatterfile that I used in the thread: http://chinamobiles.org/showthread.php?34423-I-need-CWM-For-GT-N7102-MTK6577
This is the Anhang anzeigen MT6577_Android_scatter_emmc.txt (I've modified the value "__NODL_FAT" to "FAT"):
PRELOADER 0x0
DSP_BL 0x40000
MBR 0x600000
EBR1 0x604000
__NODL_PMT 0x608000
__NODL_NVRAM 0xa08000
__NODL_SECCFG 0xf08000
UBOOT 0xf28000
BOOTIMG 0xf88000
RECOVERY 0x1588000
SEC_RO 0x1b88000
__NODL_MISC 0x2188000
LOGO 0x21e8000
__NODL_EXPDB 0x24e8000
ANDROID 0x26e8000
CACHE 0x227e8000
USRDATA 0x428e8000
FAT 0x810e8000
__NODL_BMTPOOL 0xFFFF00a8
tommy0815
please create new scatter with droid tools from your device.......where did you get this scatter or is it already from droid tools?
AW: Problem Install CWM GT-N7102
Please read back your own scatter file from smart phone at first and compare with the file from thread.
leonard9500
Here are the two scatters:
1. This is from the thread: http://chinamobiles.org/showthread.php?34423-I-need-CWM-For-GT-N7102-MTK6577
PRELOADER 0x0
DSP_BL 0x40000
MBR 0x600000
EBR1 0x604000
__NODL_PMT 0x608000
UBOOT 0xf28000
BOOTIMG 0xf88000
RECOVERY 0x1588000
SEC_RO 0x1b88000
LOGO 0x21e8000
ANDROID 0x26e8000
CACHE 0x227e8000
USRDATA 0x428e8000
__NODL_FAT 0x810e8000
2. This is the one created by the droid tool:
UBOOT 0xF28000
BOOTIMG 0xF88000
RECOVERY 0x1588000
SEC_RO 0x1B88000
LOGO 0x21E8000
__NODL_EXPDB 0x24E8000
ANDROID 0x26E8000
CACHE 0x247E8000
USRDATA 0x468E8000
FAT 0x689E8000
__NODL_BMTPOOL 0xFEAFFFFF
As you can see the only difference between them is the line "__NODL_FAT", but I've used both scatterfile and I'm getting the same error 8038.
This thing is really really driving me crazy!!, I want to throw this device through the window!!!.
