n7102 breaked need help please
tommy0815
ok sounds good..
can you tell me build nr of your phone?
or can you show me a link to the phone in web?
There are diffrent kinds of N7102!
Do you have haipai one?
dreampowerfx
http://www.*****************.com/n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core-1gb-3g-wifi-gps_p5082.html
Link http://www.*****************.com/n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core-1gb-3g-wifi-gps_p5082.html
The link is http://www.*****************.com/ n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core-1gb-3. g-wifi-gps_p5082.html
http://www. *****************.com/ n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core- 1gb-3g-wifi-gps_p5082.html
The ******** is. whole saleon epiece
dreampowerfx
And just join all parts of the names of the link in inside of the phone it only says GT-N7102
Doppelpost zusammengefügt nach 4 minutes:
tommy0815
can't see even one link....may you sent me than again, by private mail?
but please leave some spaces between... like w w w
dreampowerfx
i just send an private mail
Doppelpost zusammengefügt nach 23 minutes:
w w w . w h o l e s a l e o n e p i e c e . c o m /n7102-android-41-phone-55-inch-ips-720p-screen-mtk6577-dual-core-1gb-3g-wifi-gps_p5082.html
dreampowerfx
Hardware : SMDK4x12
Model : GT-N7102
Build number : JRO03C.N7100ZSALIA
Build date UTC : 20121222-122033
Android v : 4.1.1
Kernel v : 3.0.31-178067 (se.infra@SEP-113) (gcc version 4.4.3 (GCC) ) #1 SMP Sat Dec 22 20:17:53 CST 2012
Uboot build v : MAIN2.2.ubt.32381
LCD Driver IC : 1-nt35516_6575_dsi
Baseband v: MAUI.11AMD.W12.22.SP.V5, 2012/07/21 12:16
I have never seen a tutorial.
Here it is explained, but only in german: click
It begins after the picture "download OK"
The part after "EDIT: Hier mal schnell eine Anleitung um die Display Anzeige Fehler und Co. zu beseitigen:"
There is also a download link for the flashtool.
tommy0815
ah ok got it thx....but not really helpfull....if you will find a real tut will be very nice....because there are so many features, but don't know how to use them..
