können wir das Tool ROM Toolbox auch unseren Handy benutzen
Unimatrix 7of9
hat schon mal einer das App auf seinen Handy getestet?
Rom Toolbox: play.google.com/toolboxpro
★ ROM Management ★
☆ Install ROMs & themes from a growing list of ROMs. AOKP, CyanogenMod and other popular ROMs included.
☆ Create, manage & restore nandroid backups
☆ Wipe data, cache, dalvik-cache, battery stats
☆ Install multiple ROMs & ZIPs from your SD card
★App Manager ★
☆ Batch backup & restore apps and their data
☆ Schedule backups to run at a certain time
☆ Restore apps from nandroid backups
☆ Backup/Restore text messages, bookmarks, accounts, etc.
☆ Backup your apps to dropbox
☆ Freeze/Defrost system & user apps
☆ Backup/restore Android Market link
☆ Task manager
☆ Automated batch uninstaller
☆ E-mail your apps to friends
☆ Move any user app to the SD card
☆ Clean up dalvik-cache
☆ Zipalign, fix permissions, wipe data & cache, force close any app
★Root Explorer ★
☆ Access the whole of android's file system (including the elusive data folder!).
☆ Batch copy/paste, zip, tar, delete, move any file or folder
☆ Change file permissions and ownership
☆ View, edit & share files
☆ File manager with two panels for easier management
★ Scripter & Terminal Emulator ★
☆ Create and run scripts as root
☆ Set your scripts to run at-boot
★ Auto Start Manager ★
☆ Enable/disable apps that run on start-up
☆ Enable/disable any broadcast receiver, activity or service
★ Rebooter ★
☆ Reboot recovery, powerdown, bootloader, restart status bar, etc.
★ Font Installer ★
☆ Install custom fonts from a huge list or from your sdcard
☆ Set fonts as favorites & send them to friends
★ Boot Animation Installer ★
☆ Install custom boot animations from a huge collection or from your sdcard
☆ Preview boot animations
☆ Create a boot animation from a GIF file
☆ Have a new random boot animation each time you boot-up!
★ Theme Manager & Statusbar Icon Changer ★
☆ Create and install full themes (MetaMorph compatible)
☆ Customize your status bar by installing custom icons for wifi, signal, gps, etc.
☆ Change your battery icons in the status bar to a custom one from a list of 200+
★ Boot Logo Changer ★
☆ Change your boot logo for supported phones
★ Theme Chooser Themes ★
☆ View a list of themes for the TMobile Theme Chooser
★Set CPU★
☆ SetCPU & scaling governor
☆ CPU Profiles
☆ Kernel tweaks to speed up performance
★ Build.prop Editor ★
☆ Easily edit your build.prop
☆ Change lcd density, improve battery life, increase performance
★ Auto Memory Manager ★
☆ Set minfree values & select from presets. Apply values at boot
★ SD Booster ★
☆ Increase the speed of your SD card
Permissions
Contacts - Backup call log and sms
SMS - Backup call log and sms
Accounts - Backup and restore from Google Drive
Unimatrix 7of9
Danke für Deine Antwort.
Was möchte ich wissen?
1 Install ROMs & themes from a growing list of ROMs. AOKP, CyanogenMod = kann man da mit denn Rom einfach austauschen? findet er denn richtigen?
2 Boot Animation Installer = geht das mit der Bootanimi
3Theme Manager & Statusbar Icon Changer = kann man es auf allen Handys benutzen?
oder einfacher geht alles? z.B. auf dem
Upai-n7100+
LG
R
rWx
Das wird wohl nicht funktionieren, für das Modell gibt es keine AOKP oder CM ROMs. Ich würde auch nur über CWM oder mit Flashtool eine andere FW installieren.
Könnte funktionieren, hab ich selber aber über CWM gemacht.
3 Theme Manager & Statusbar Icon Changer = kann man es auf allen Handys benutzen?
Das funktioniert nicht mit den MTK Modellen, hatte es mal probiert aber selbst die Statusleisten Icons werden nicht geändert.
robby4
@Unimatrix 7of9
Wenn du die Rom benutzt die ich dir im anderen Thread empfohlen habe kannst du mit der UOT Kitchen deine Statusbar modden, du mußt nur die framework-res.apk und die SystemUI.apk aus der Rom extrahieren, am Ende bekommst du eine *.zip Datei die du über das CWR flashen kannst.
EDIT:
Ich hab mal die Rom Toolbox gekauft und mit meiner deodexed Rom kann man die Statusbar icons ändern, auch wenn bei den von mir getesteten Akku Icons der für 20% Akkuladung fehlt.
