GPS Problem
tommy0815
Hey Sumon,
i already showed you posting from N2K1. It will work 100% for you, please try it!!
If you don't understand what to do, so ask, but it will work!
tommy0815
ok i will try my best....i will edit this posting here soon.....but it isn't that easy because i can't do in real, so please be patient!
Edit:
here you can find the Post from N2K1 again:
http://chinamobiles.org/showthread.php?33250-Firmware-fuer-HDC-GT-N7102&p=363679&viewfull=1#post363679
I try to get it in short:
please try:
1. please delete the file "mtkpgs.dat" as N2K1 wrote you will find in "/data/misc/mtkpgs.dat"
2. please activate A-GPS and EPO
3. create outside a new file while using YGPS
tommy0815
you have to go outside with you phone and create a new file with the app "ypgs" (have a look in system and than app folder you will find there!)
sumon530
at step 3 , just go to system/app/ and then click ygps .. it says install ygps.., click install ,then show install complete.. go to maps.. but after 30 sec say network location unavailable..
tommy0815
ok i can't help you in this point how this exactly work, because i won't create this (because my GPS is working), maybe you can ask "composer" how this step will be done correctly.
Sorry, but can't help you this way.....
N2k1
Oh, no!
Do not click this file into a browser!
You must enter engineer mode (you can do this with some dialer command (on my phone *#*#1478963#*#*) - or via the mobileUncle tools)
Now you can run YGPS and wait until the fix.
But there is an other musthave before: Your system time and time zone is necessary to set correct!
(You can do this with the app fasterfix - and in Settings date&time to Network time.)
N2k1
Click on INFORMATION ans look te TTFF (time to first fix) and latitude/logitude - there should be a value (not running time in ttff field!)
