Star V12 mit MTK6577
sardaar
I have found a way to flash my phone with a good ROM with Google Apps (including the Store!), here is my procedure. (Enschuldigung, mein Deutsch nicht gut für einen so lang und technisch Text)
uleFone V1277 / Star V1277 MTK6577 ROM Flash procedure
Warning:
This procedure is from my personal experience with my own uleFone V1277. I can't guarantee that it will work with your phone.
Greetings:
Thank you to the community of the following forums and websites:
-http://forum.china-iphone.ru (For the ROM)
-http://chinamobiles.org (For the flash tool)
-http://bm-smartphone-reviews.blogspot.fr/2012/05/mt6575-flashing-tutorial.html (for the help)
What do you need.
• SP Flash Tool: SP_Flash_Tool_v3.1222.00 software SP_Flash_Tool_v3.1222.00 - Downloads - Chinamobiles.org
• A ROM, I used this one: V1277-1009T_120807_OV5647_ICS2V1_V02_COM_EN
Яндекс.Народ
• Windows XP (I didn't tried with Vista/7)
How go in "Flash" mode
-Turn off the phone
-Remove the battery
-Replace the battery
-Plug the phone into the computer
After that, Windows should ask for the driver.
How to install the driver
The driver is in the \SP_Flash_Tool_v3.1222.00\new usb driver directory. The hardware name is. MediaTek PreLoader USB VCOM Port:
TIP:After the installation of the driver, the phone will show an battery logo and will disapear from the Device manager list. thats, OK, the phone will not stay in "Flash" mode if it doesn't receive instruction.
How to use SP Flash Tool
Thats easy, but need a good timing
First, shut down the phone and remove the battery.
Launch "\SP_Flash_Tool_v3.1222.00\Flash_tool.exe
Sélect the "Scatter-loading" file:
"\V1277-1009T_120807_OV5647_ICS2V1_V02_COM_EN\BIN\MT6577_Android_scatter_emmc.txt"
Warning: The "\SP_Flash_Tool_v3.1222.00\MT6577_Android_scatter_emmc.txt" file is almost identic but will cause problems with the user partition.
The .img files list is automatically updated
Press the "Download" button. The program will wait for the phone
Plug the battery in the phone and plug the phone to the computer
If the driver isn't already loaded, windows will ask for the driver
Flash procedure will begin. The progress bar will change of color and will finish with a green "O"
Now I need help to find a way to Root this phone
celm72
Da mein Englisch für diesen langen Text nicht ausreicht kann ich damit leider nichts anfangen.
Colonel Zap: könntest du mir in dieser sache weiterhelfen?
Petteri
Soll Dir der Colonel jetzt den Text übersetzen!? :)
Mei, dies ist einfachstes Englisch, damit kommt sogar der Google Übersetzer klar!
Grundsätzlich mache ich dies nicht, aber hier mal schnell von mir übersetzt:
-Turn off the phone Schalte Dein Handy aus
-Remove the battery Nimm die Batterie raus
-Replace the battery Setze die Batterie wieder ein
-Plug the phone into the computer Verbinde das Handy mit Deinem Rechner
How to install the driver Wie muss man die Treiber installieren?
der Treiber ist im Ordner \SP_Flash_Tool_v3.1222.00\new usb driver. Die Hardware ist: MediaTek PreLoader USB VCOM Port:
Tip: Nach der Installation der Treiber zeigt das Handy sein Batterie Logo an, was nicht schlimm ist, es wird nicht im Flashmodus bleiben wenn es keine Anweisungen bekommt dies zu tun.
How to use SP Flash Tool Wie benutze ich das Flash Tool?
Thats easy, but need a good timing Dies ist einfach, man braucht aber bissl Geduld und gutes Timing!
First, shut down the phone and remove the battery. Als erste schalte das HAndy aus und entferne den Akku
Launch Starte "\SP_Flash_Tool_v3.1222.00\Flash_tool.exe
Sélect the "Scatter-loading" file: Wähle nun den Scatter File aus
Warnung: Die "\SP_Flash_Tool_v3.1222.00\MT6577_Android_scatter_emmc.txt" Datei ist identisch aber es können Partitions Probleme entstehen
The .img files list is automatically updated Die .img Datei wird automatisch erneuert.
Press the "Download" button. The program will wait for the phone Drücke nun den Download Button...das Programm wartet jetzt auf die Verbindung miot dem Handy
Plug the battery in the phone and plug the phone to the computer Setze die Batterie wieder ein und verbinde das Handy mit dem Rechner
If the driver isn't already loaded, windows will ask for the driver Falls der Treiber noch nicht geladen ist, fragt Dich jetzt Windows danach um zu installieren
Flash procedure will begin. The progress bar will change of color and will finish with a green "O" Das flashen beginnt, in der Fortschrittsanzeige siehst Du Farbveränderungen und wenn das grüne "O" kommt hast es geschafft.
celm72
Hallo Petteri:
so war das nicht gemeint!
Ich will das Handy dabei nicht zerstören und ich hatte auch noch nie eines gerootet und nebenbei soll es auch noch Menschen geben die kein Englisch hatten. Traurig aber wahr.
Ich will einfach nicht kaputt machen.
Vom Prinzip ist das nichts anderes als das:
[video=youtube;ANlsqVWu_ks]http://www.youtube.com/watch?v=ANlsqVWu_ks[/video]
Petteri
Hallo Petteri:
Kein Problem! War ja schnell gemacht! :) Hauptsache es hilft zusammen mit Colonels Video! :)
celm72
Das wird mit Sicherheit helfen. Ich werde es heute abend versuchen, da habe ich genug Zeit.
Erstmal vielen Dank an euch:ok:
sardaar
Stryper
Also, es hat problemlos geklappt.
Einfach die Anleitung befolgen und es geht wie geschmiert.
Google Play ist schon drauf und man kann ua. Deutsch auswählen.
So jetzt muss es noch gerootet werden, mal schauen ob das auch so einfach ist.
mfg
stryper
Petteri
mfg
stryper
Wie gut das ich übersetzt habe! :) Na dann viel Spaß mit dem Gerät....
sardaar
Leider nicht. So wie es z.Zt. aussieht lassen sich MT6577 Handys nur rooten, indem ganz schlaue Menschen Rootrecht etc. in ein Bootimage einkochen, das dann geflasht werden muß.
Mein Colonel, es wie eine Herausforderung für mich ;-)
Hier ist ein Lösung für Rootrecht werden: Star V12 (V12+/V1277) MTK6577 Forum.China-iPhone.Ru
Ich habe es hier kopiert : ROOT V1277
In Englisch es ist:
1. Connect your phone to your PC, install the drivers;
2. Enable USB debugging Mode in the Phone;
3. Unpack the archive;
4. Start mkroot.cmd, wait three reboots.
Es werk mit mein V1277
Ich hoffe, das Handy bleibt sicher. (Ohne Russisch Virus / Trojaner / Andere Überraschung)...
celm72
Auf die Gefahr hin das mich alle für unfähig halten; ich finde den Treiber nicht. Mein Rechner hat Windows 7 und unter dem angegebenen Ordner im FlashTool finde ich keinen Treiber.
