Apad YX9A01 - 1.5GHz Amlogic dual core 9,7" IPS ICS 1G ram bis 16G Speicher ab 900¥ ?
J
johndebur
hat angeblich auch ein Metallgehäuse, wenn ich die Übersetzung richtig verstehe. Einführungspreis , wahrscheinlich mit 4 GB Speicher, soll unter 800 yuans sein, wenns stimmt.
Hat nen AMlogic dual core chip mit 1,5ghz und Mali-400 MP2 GPU , 9,7 " IPS display , 1GB Ram , jeweils mit 4GB 8GB oder 16GB Speicher, 7600mAh Batterie und Android 4.
Angeblich hat das tablet auch eine Google CTS certification, was auch immer das ist, auf jeden Fall wird da erklärt, daß dann der Google app store im Ausland besser gehen sollte.
shanzhaiben link
The Yongxiang 9.7 inch AMLogic dual-core tablet release, pre-sale price of $ 8XX
Understand what Yongxiang is offering a dual-core APad tablet parameters, AMLogic 8726-MX processors, the Cortex-A9 dual-core, the highest clocked at 1.5G. Mali-400 MP2, graphics core, 9.7-inch IPS capacitive screen (touch), standard 1G memory, storage optional 4/8/16G, 7600mAh battery capacity, Full Metal Jacket, front and rear dual camera, the pixels of 30W and 200W Android4.0.3 system. The whole price of $ 8XX, manufacturers can also be a separate supply PCBA board.
And this APad tablet by Google CTS certification, the CTS certification more and more foreign buyers as a rigid procurement indicators. The Android system is now a large number of manufacturers using various hardware platforms, product specifications vary widely, such as display resolution, increase or decrease of the various types of sensors. In order to ensure the application software in the Google Market is perfect in every Android device running Android compatibility test standard CTS, this standard to regulate the Google Market application of this the APad through this certification represents compatible applications, the software runs on all or most of the Google Market is more stable.
▲ 9.7-inch IPS screen, wide viewing angle, color, size of the Tablet PC of choice for gold.
▲ capacitive touch screen, 1024x768 resolution, can support up to 10 touch.
▲ ecological Android4.0 desktop.
▲ Front 30W pixel camera head.
▲ the bottom shell of the all-metal material.
▲ provide definition HDMI interface, USB OTG-specific extension interface, TF card slot.
▲ top of the return key and adjust the volume.
▲ Rear 200W pixel camera.
▲ setting interface, the original model of the flat YX9A01, also known as APad.
▲ Z - Device the TEST detection part of the hardware results: 1.51G processor 2, the highest frequency, the current operating frequency, 1.2G, hardware appear as Amologic Meson6 M6 is the internal chip code, more popular name for MX.
3_201206151521343Osou.jpg3_201206151521342R817.jpg3_2012061515213461zry.jpg3_20120615152134899sR.jpg3_201206151537101Uq4e.jpg3_201206151521341SAm5.jpg3_2012061515213446aiB.jpg3_201206151536561zG5B.jpg3_201206151521347pbBU.jpg3_201206151521345e8WL.jpg
Luboo
Wie was ???? Wären dann doch nur... so um die 85€ richtig? Kann doch nicht wirklich sein... wenns so wäre wäre das wirklich "a bargain"!
J
johndebur
ja ich weiß auch nicht, kommt halt dann noch Porto, Versand, Zoll, Einfuhrumsatzsteuer, Gebühren für den Zwischenhändler, irgentwelche Bearbeitungsgebühren, dann wird zehnmal das Falsche versendet, und am Schluß waren es doch 400 € lol :p
Luboo
Lol true true... aber wenn man nen netten Chinesen oder einen Kollegen hat der sich beruflich ständig im Osten auf Messen rumdrücken muß kann man da schon mal drüber nachtdenken sich so ein Teil zu zu legen ;)
JoeDB
NEIN! schau mal hier http://www.xe.com/ucc/convert/?Amount=900&From=CNY&To=EUR, entspricht aktuell 112 Euro etwa, wird wahrscheinlich noch mehr die tage, weil euro an wert verliert
trotzdem sehr günstig, aber ein noch relativ unbekannter Hersteller, kann also gut sein, daß hier und dort wieder Hardware eingespart wird (langsame speicher / zu wenig, schlechte WLAN Module etc.), würde da lieber zu nem Markenprodukt greifen.
Habe mir letzte WOche das RAMOS W17Pro bestellt. mal schauen wie es wird.
Luboo
Das Ramos hört sich auch nicht schlecht an aber 7" sind dann doch vielleicht etwas zu klein... übrigens bezweifle ich, dass das ein echtes "Markengerät" ist ;) ...was aber so richtig geil ist ist der Vergleich mit der Münze... die Chinesen haben riiiiiiiesige Münzen XD ramos_w17_pro_in_stock.jpg
