Smart Devices Q8 - Dual Core 4" Alu tablet ICS 120€ ?
J
johndebur
Smart Devices will ein tablet für unter 1000 yuans herausbringen, das mit einer Dual Core OMAP4430 CPU von Texas Instruments ausgestattet ist. Das Gehäuse ist aus Aluminium und das display ist ein 4" mit 1,024 x 768 Auflösung. Außerdem läuft es mit Android 4 , hat HDMI und hat nen G sensor etc. gar nicht schlecht. :) sieht auf jeden Fall schick aus
shanzhaiji link
PConline link
smartdevices link
Produktseite:
SmartQ-Q8
Smart Devices Wizard Q8 Dual-Core Tablet PC is listed on the 8-inch screen priced at 998 yuan
Chi will this dual-core Tablet PC named Wizard Q8, in fact, also uses Texas Instruments' OMAP4430 processor. On the overall appearance of the aluminum alloy back panel of the all-metal design, design like a flagship dual-core brothers machine T20. Screen for the level of 8-inch XGA 1,024 x 768 resolution, you read that the proportion of point of view is 4:3, pre-loaded with Google Android 4.0 system. If there is no accident, still equipped with their own R & D of Smart Devices Chi-reading software and electronic bookstores.
Also equipped with 1GB of RAM and comes with HDMI output, and T20 are different before and after each of a 200 million pixel camera, in addition to the three-axis gravity sensor, a Micro SD interface supports up to 32G capacity expansion cards and OTG tall, has been reduced, 4,800 mAh battery capacity. Now the price of 998 yuan, will be the official website of Smart Devices online store sales, are interested can go to the next; can be expected that the price of domestic dual-core Tablet PC will be more affordable.
Smart Devices Tablet PC again affectionate embrace the U.S. Texas Instruments (TI) OMAP4 dual-core, Q8 uses TI's OMAP4430 dual-core processors, and strong performance, the cores separate operating frequency up to 1GHz, provides more power for the efficient operation of Q8. Q8 GPU OMAP4430 integrated Power VR SGX540 pixel fill rate of the operating frequency of 300MHz and 1000M / S is very eye-catching, 3D games and other 3D user interface performance.
Smart Devices Q8 equipped with a dual-channel memory technology, Texas Instruments (TI) OMAP4430 dual-core processors
TI's OMAP4430 has a symmetric multiprocessing (SMP), the use of the IVA 3 hardware accelerator to achieve the full HD 1080p multi-standard video encoding / decoding, faster, higher quality image and video capture function. With 1GB of RAM, Q8 has even better performance in system response, and document processing.
0054572.jpg2754383_6_thumb.jpg0054571.jpg2754383_3_thumb.jpg0054570.jpg2.jpgq8_005.jpgq8_010.jpgq8_011.jpgq8_006.jpgq8_004.jpg
Loonix
Spokenkieker
uhm, 4" oder 8"?
die Bilder und die Beschreibung und die 1024x768 Auflösung passt auf eden fall eher zu einem standard 8" gerät.
//EDIT: lol, zu langsam gewesn ^^
J
johndebur
hab da wohl falsch rumkopiert, sind halt zuviele Zahlen :grin: Wäre ja sonst ein handy :p Vielleicht kann man ja die überschrift verbessern.
anscheinend kann man direkt beim hersteller bestellen, wenn es zu haben ist SmartQ—Purchase
Loonix
Spokenkieker
jupp,
4" mit 1024x768 er auflösung und HDMI ausgang hört sich aber als Mediaplayer auch nicht ganz schlecht an.
J
johndebur
lol kann man ja mal denen vorschlagen, dann noch Alugehäuse . Wird ein bißchen schwer. :p
J
johndebur
naja hatte die 998RMB mit google umgerechnet
[h=2]998 Chinese yuan = 120.925375 €[/h]
kommt ja auch noch Porto einfuhrumsatzsteuer etc dazu. :) Also End Preis wird dann eh über 200€ :p
