Ruixin 13.3" MacbookAir Klon mit magnetischem power connector
J
johndebur
Ausstattung klingt nicht schlecht , hat sogar das originale Stromkabel mit Magnet zum AUfladen. Kostet 1500 yuans.
超高仿MacbookAir,创瑞鑫13.3寸笔记本 - 山寨笔记本网  平板电脑资讯站,平板电脑,iPad,平板电脑批发,山寨iPad,iPad皮套,山寨笔记本,山寨本
High imitation MacbookAir, creating Ruixin 13.3-inch notebook
The following record from Shenzhen Ruixin notebook, look absolutely most important feature, the perfect reproduction of the classic Macbook air all the details, including overall appearance, magnetic power connector, keyboard, touchpad included, quite similar to the point where machines the body also uses the unibody design, the plastic material, the price is only 1,500 yuan.
Configuration is relatively mainstream netbook configuration, Atom D525 dual-core processor, clocked at 1.8GHz, 2G RAM, 64G SSD, 13.3-inch 1366 * 768 screen, running WindowsXP system, very fast, with a front camera, two USB expansion port, HDMI output, multi-function SD card reader.
The following real shot to bring real machine demonstration.
Appearance alone is almost the real thing, metal and plastic feel slightly different, the whole weight of 1.4kg, 100g weight than the MBA is really about.
Silver casing part.
Chocolate keyboard, large touch pad, blade edge design.
Magnetic interface.
Power adapter, and Apple's MagSafe power adapter is exactly the same shape, with a magnetic interface is a perfect match.
The right side is the SD card slot, USB, HDMI port expansion.
The appearance of doing very well.
Keyboard real shot, and the Apple keyboard size is one to one.
Shaft part.
The power button in the upper right corner of the keyboard, and MBA the same.
Set up a special numeric keypad switch region, it is very do.
Large trackpad, and macbook series as large, easy to operate.
Thinnest place.
On the back.
And the MacBook Pro to a photo on the left illuminated MacBook Pro puzzled and asked: "Did you I lost brother?"
In addition to the force of the very appearance in the configuration of this laptop is also quite good, especially the use of the SSD so that overall performance has been very significant leap forward.
Contact the manufacturer:
Company: Shenzhen City, a Ruixin Technology Co., Ltd.
Contact: Xiong Jingli
Tel: 13715235938 0755-83258696
Display counters: Shenzhen Huaqiang North electronic market 2A051 SED
3_201112271050578RMkS.jpg3_20111227105057116Lm8.jpg3_201112271050573BN7x.jpg3_2011122710505779oqt.jpg3_201112271050574OpWw.jpg3_201112271440481KI9l.jpg3_2011122710505758nz6.jpg3_201112271439131VCZv.jpg3_201112271050571gg2O.jpg3_201112271430561vzBz.jpg3_2011122710505710JcsB.jpg3_20111227105057122828.jpg3_201112271050576EsFN.jpg3_201112271050579LQ8R.jpg
Nomex
mir ist wayne was die da installieren, hauptsache die dinger gibts überhaupt mal. installieren kann man es selber.
