Ramos - 5mm dünnes tablet
J
johndebur
erste Bilder vom 5mm dünnen tablet von Ramos. Steht jetzt nicht da was es kosten soll, was es leistet, nur das es 5mm dick ist.
Es wird nur spekuliert, daß es eventuell mit Android 4.0 herauskommen könnte.
最薄5mm?蓝魔音悦汇“薄冰”平板电脑登场-新机-山寨机网
Thinnest 5mm? Blue Devils Yin Yue Department "thin ice" Tablet PC debut
Blue Devils following the score Yin Yue Department's 7-inch flat-panel W3HD listed, the whole new generation of 8-inch flagship model also marks the beginning exposure, revealed a few products from the exposure map, you can see some of the major features of the new machine, continuation of the Blue Devils in the design of the previous flagship product characteristics:
Thinnest at less than 5mm, while the overall thickness of the thinnest W10 relative to this year's product, the thickness should be reduced by 30%.
Ultra-thin body needs with superior manufacturing processes and quality materials in order to show a good texture, can be judged from the exposure map, the body should be built of metal alloys. The edge of the new machine design: sleek rich three-dimensional curvature, from the reflection can be judged on the edge, I believe it must be true of visual effects, and this smooth hand feel on the edge I believe it has been optimized.
You can see the whole touch screen with a flat front design, I believe this is the Blue Devils at the conclusion of the digital user preferences ongoing improvement after an embodiment. The back is very simple, you can see the metal wire drawing process coverage.
From multiple exposures to determine the overall figure, the Blue Devils in the design of the new machine, changing the previous ideas and style, completely non-existent once the shadow of the product, is a new sense of industrial design, popular style in imitation iPad today, believe will bring about a new flat price of domestic mainstream fashion trend, while Android4.0 system will also be listed at the same time with this product.
7-inch tablet in the domestic market is more and more, this time we take a look at the new Blue Magic Android plate capacitor W3HD seven inches, the price still is taking the cheap route, the market price of $ 899 / 8GB, which makes the opponent fold sense of pressure, we have to look at what the material. Configuration from the specification point of view, this 7-inch screen with 1024 × 600 resolution, with Anti-glare anti-glare coating technology, A8 processor core, 512MB DDR3 memory, front and rear camera design, the specifications for the pre-300 000 pixels, rear 2 million pixels. We take a closer look at this real flat.
J
johndebur
naja sieht man ja auf dem bild die dünnste kannte ist 4,93mm. kann natürlich sein, daß das meßding schlecht geeicht wurde :) wird zur mitte hin auf jeden fall dicker :grin:
aber egal sieht doch schon schick aus
cliffgull24
