Hello
I own a Yota Max4g and i did try to upgrate it's firmware.
Following the steps, as described in this video -> http://www.youtube.com/watch?v=-DaHt3OLUos
all seemed to work fine, till the step where i connect the phone.
IDT says "Phone Checked" and after 2 seconds it says "UE not entry download mode!(Mode 0x00)" and result turns to "FAIL"
Trying to solve this myself ended up on me being unable to even hard reset the phone. It keeps rebooting on and on.
So at this moment my phone can be in 4 conditions:
1. Normal open which ends up on infinite rebooting
2. Volume UP + Vol DOWN + Power on, which goes to hard reset, it does it and returns to infinite rebooting
3. Volume UP + Power on, which goes to "Calibrating" Screen, and if connected to IDT says UE not entry download mode but mode says 0xC0
and last
4. Volume Down + Power on, which goes to "Downloading..." screen, if connected to idt says the message described above.
Searching for hours didnt come up with something, so, any help would be greatly apreciated!
Thanks in advance
and last
Thanks in advance
