iPDA Wm 7 - ipad alternative?
Witstech A81??????????
Die genaue Typenbezeichnung weiß ich leider (noch?) nicht ;)
Ist auf jeden Fall ein 7" Gerät und der Benchmark kann sich sehen lassen :)
Ich teste noch :)
J
johndebur
Samsung Galaxy Tab klon ist angekündigt.
http://shanzhaiben.com/48/n-4848.html
It is reported that Shenzhen is a manufacturer and Samsung have developed a cloned version of the same appearance, the proposed PV210 uses a Samsung processor, based on the Cortex-A8 core, 512M memory, Android2.2 version, 7 inch LCD screen, touch side is not clear capacitive screen, or resistive screen. If the capacitive touch, then the original configuration and on similar, is expected to wait years before there will be more information released.
Cottage version of the P1000 is expected to be less than the estimated price of 2,000 yuan, good price. And high-end processor core based on A8A9, has been able to have a good experience. Xiao Bian also always concerned about this machine, give us the news report.
_____________________________________
COSMO kingdbook K10 mit Dual OS , Android und Windows 7. Läuft mit nem Atom chip, leider nur mit resistivem touch.
http://midbbs.cn/html/pingcedaogou/201101/15-3785.html
And the general configuration is not much difference between X86 Tablet, N455's CPU, 1G memory, 16G SSD, a typical Internet configuration, pre-installed dual-system Windows7, and Android 10-inch 1024 * 600 resistive touch screen two.
Right of the screen design of the three function keys, using a longitudinal design flat major, from top to bottom as the power switch, function keys and function keys for a second, the former press opening of the virtual keyboard, press the "ESC" key , which press on or off Wi-Fi / Bluetooth, press on or off 3G, the OK button before entering the system.
Camera is 1.3 million can take some simple video chat and photos.
Body size: 243 * 190 * 14.5mm
Dual-boot system switch, Android-X86 is more than enough to run on the Atom, Windows7 is easier for the next application.
16120564577.jpg16120521630.png16120520465.jpg16120545241.png16120561922.jpg161205EJ6.jpg16120525198.jpg
J
johndebur
ach ok :) aber hier ein Windows 7 tablet mit 9,7" kapazitivem screen und Intel Atom Z530 Chip:
http://shanzhaiben.com/50/n-4850.html
Talk about the configuration of this machine, using the Atom Z530 processor, clocked at 1.6GHz (Z series CPU is used in the MID category of device, also used in some laptops, such as the VAIO P), 1G RAM , 16GB SSD hard drive, the screen area is very strong and is used in the same 9.7-inch IPS iPad view full-screen (LG), configuration of a capacitive touch screen.
Capacity of the local battery 3800mAh, support the four-way rotation of gravity to support the built-in 3G module, the body is reserved for 3G SIM card slot. Machine's size 243x190x13.9mm, slightly thicker than the iPad. Weighs only 640 grams, thanks to using the FLASH memory, and Z series of low-power design allows more light can be done.
In addition to the adapter box with accessories, but also with an extension USB box (with 3 USB ports).
The radio button corresponding to the front fuselage is the Start menu at the top has a built-in camera. There are a number of interfaces and buttons above, namely the power button, headphone socket, reset.
3 side switch is locked and the touch volume adjustment.
A data interface to the bottom line. Native speakers with 4 holes, so loud.
Back of the fuselage without any logo branding and certification, which is a lot of cottage features of the product. 3G SIM card hidden in the top of the black plastic cover.
Contact:
Ruixin Technology Co., Ltd. Shenzhen,
Xiongjing Li 13715235938
3_201101180932321AAwp.jpg3_20110118093301119ju.jpg3_2011011809322817Brr.jpg3_20110118101022146RQ.jpg3_201101180931391zjHC.jpg3_201101180932571FtuV.jpg
J
johndebur
neues 1ghz Tablet, P702. Das witzige sind die zwei Kopfhöreranschlüsse, damit man auch zu zweit nen Film ansehen kann.
Allerdings ist der Prozessor von 720 Mhz auf 1ghz übertaktet, keine Ahnung ob das wirklich vorteilhaft ist, und es nicht besser ist gleich einen 1ghz prozessor zu nehmen. naja.
Läuft mit Android 2.2
http://shanzhaiben.com/70/n-4870.html
Year introduced the first Tablet PC from Shenzhen DNT, the tablet is still using the TCC8902 configuration, but there are some differences. Dual headphone jacks with couples, watch a movie together to share songs is a very romantic thing.
Processor: TCC8902 frequency 1G, after overclocking treatment, TCC8902 default frequency is 720MHz
Memory: 256M
Screen: 800 * 480 screen resistance, to support two touch
Size: 191 * 119913.3mm
Weight: 350g
System: Android 2.2
Audio output, memory card slot, USB, HDMI, audio output, RESET hole, power input, dual headphone jack is designed to be easily shared with others, which is relatively common in the MP4 .
Equipped Android2.2 system can not support flash10.1 plug (according to the manufacturer said that it would soon chip in 8902 to support FLASH10), have been greatly improve the speed, free memory during idle time can go to 100M, in memory using the control on Android2.2 a great improvement over 2.1.
Web browsing, frequency upgraded, TCC8902 corresponding increase in operating speed, of course, will increase power consumption, built in 2000 * 2 4000mAH battery.
Another strong point is the video playback TCC8902, 7-inch TCC8902 is relatively flat in this perfect, little redundant in this classification.
Summary: This plate and the speed compared to previous products has improved, relatively smooth load the page, the system upgrade to Android2.2 most obvious is to change the speed, the basic application is sufficient. As an upgraded version of P7, upgraded marginally, mainly on the basis of partial and detail enhancement.
Laptop Notebook cottage made the first leg of this site
_______________________________________________
hier noch lauter Bilder vom Dual OS tablet - Viewpad 10 von Viewsonic . Das hin und her schalten von windows auf android und zurück gefällt mir, scheint ja gut zu funktionieren :)
http://www.midbbs.cn/html/pingcedaogou/201102/16-4038.html
1_110216181216_1.jpg1_110216181216_2.jpg1_110216181216_4.jpg1_110216181217_13.jpg1_110216181216_8.jpg1_110216181216_9.jpg1_110216181216_10.jpg
[video=youtube;g7gNOXF4guE]http://www.youtube.com/watch?v=g7gNOXF4guE[/video]
[video=youtube;fHTOT0LEkmY]http://www.youtube.com/watch?v=fHTOT0LEkmY[/video]
