mtk hd2 wifi issue
Petteri
Ok, that will help! :)
but i dont know how i can help..thats courious! Normally there is an extra Point in this Setting (picture 2) that is called "WiFi"! Sooo, you have not! Never seen before...
Like you will see on my Settings!
jakubokaj
That's my problem,
I've tried several ROM's but always the same.
If I install another manager with that option he try to run and after few seconds come back to off.
Is there any way to chceck hardware?
Added after 16 minutes:
Strange but works, after two soft resets ( I didn't do before) and manual IP setting ;) Now Icon is connected with Wifi search and works.
From other side:
Do you know how I can run mobile sense?
Petteri
Oh, nice to hear! Never had your Problems before! :)
Mobile Sense works if you minimum installes SPB MobileShell 3.5.3 on your Phone...after full Installation, you have to install MobileSense, it will all install by itselfs then!
wienio
Mike (etowalk) confirmed me, that it probably hardware problem. i will send the item back.
Etowalk should exchange it for new one.
We will see do the exchange service will work right ... i will write back.
Greets
Wienio
sawfish
