T3333 Dual sim Wm6.5
J
johndebur
Gibt nun ein relativ günstiges Dual Sim WM 6.5 handy.
Hat Wifi, A-GPS, GPS und das für 710 - 900 yuans.
http://shanzhaiji.cn/labs/20100806/19203.html
Windows Mobile 6.5 system, 2.8-inch QVGA touch screen, WIFI wireless Internet access, dual card dual standby, GPS positioning system and a 3.5mm universal headphone jack
T3333 back of a 2 million pixel camera, shooting people is still not in tears. The use of aluminum metal frame materials, plastic material after the shell in his hand the unique feeling very comfortable and also equipped with a next to the stylus. Gives the appearance of a very commercial feel.
T3333 processor is MTK 6516 using the dual-core architecture, application processor ARM9 416M Modem ARM7 280M, with Windows Mobile 6.5
T3333 ceramic antenna is surprised me one thing, Yibantaoci Tian Xian is used to compare the above high-end machine, and it supports AGPS Gongneng, Google Maps is great in the use of the convenient.
T3333 as a smart solution MTK system cell phone Windows Mobile 6.5, its performance is remarkable, the overall machine to others the feeling of a business machine, the dual card dual standby with the function may be said to be even more powerful a, WIFI wireless Internet access, AGPS ceramic antenna positioning and the advantages of these relatively strong, and from cost point of view, T3333 is no doubt the economy is the king of smart phones.
J
johndebur
SO nun gibt es das t3333 auch als Android handy , nennt sich da dann t3333a , ist dann also ein günstiges Android Einsteiger handy. Das Windows handy gibts ja schon für 780 yuans.
http://www.mobileuncle.com/news/devicenews/2010/0826/1845.html
World debut MediaTek MTK first Android2.1 intelligent machines will fire version T3333a
MTK Android smartphone world's first spy photos come from the Shenzhen market, a cottage called "T3333a will fire version of" smart machines, the system version Android2.1, dual card dual standby, RAM 256M + ROM 512M, high imitation Dopod T3333, work very good, non-Android old version of the "T3333 Dual SIM dual standby," the current selling price of around 780, I believe an upgraded version of this T3
Mobile uncle to get the world's first MTK Android smartphone spy photos come from the Shenzhen market, a cottage called "T3333a will fire version of" smart machines, the system version Android2.1, dual card dual standby, RAM 256M + ROM 512M, high imitation Dopod T3333, work very good, non-Android old version of the "T3333 Dual SIM dual standby," the current selling price of around 780, I believe will be an upgraded version of this T3333a fire edition will be the most cost-effective a 2.1 version of the Android model.
J
johndebur
neues vom t3333a, dem Android t3333.
Angeblich wurden lauter bugs in der Android ROm gelöst.
http://products.mobileuncle.com/thread-35222-1-1.html
Now the system has not much to BUG,
die kamera soll nicht der hit sein, aber was verlangt man auch von nem billig Android smartphone ;)
2.1 Andrews systems, T3333A up and running very smooth, beautiful interface. No way to use up some of Andrews before the tested machine jerky feeling.
Installation of several commonly used software testing (QQ, UC, UC players, etc.) are not incompatible as any! ,
Will try to use a mobile Internet, speed is very good. We look at the video. .
Please note that is a prototype. Respect to the agonizing look horrendous, and we only look at Andrews, the other ignored on the line. . In addition, the cameras are relatively poor. . We barely see!
Video im mobileuncle thread:
J
johndebur
vielleicht müssen die auch noch den Windows knopf fürs Androidhandy weg designen :)
bei taobao gibt es ja schon welche.
ach ja das handy gibts auch in weiß.
die ROM gäbe es hier, aber ist wie beim Tops A1- irgentwie kompleziert. denke mal die ganzen Läden müssen erst selbst mal ausprobieren wie das gefläsche geht .
http://products.mobileuncle.com/thread-35415-1-1.html
The first step:
To PL2303 cable plug. Installed drivers.
See Settings Manager - port is shown inside the data line
If not, do not install a good drive. Brush tool also limits the line of COM port is 3-8. Note that can not be other, COM port can be changed, right click, Properties - Port Settings - Advanced
Here you can change, and changes to determine!
Step Two:
Open the Brush tool dedicated MTK
Within the meaning of the second front, click the File option in the first (open Download ....)
Select MTK Brush tool in the MTK-AllInOne-DA
Arrows do not need to set the third
Then the fourth is the most critical
Click, and then jump to the choice of MTK Brush tool in the MT6516_scat_V1 document!
Then click the File option in the third (Scatter and ....) pop up the following options
Click xldr-Select T3333A official guide information in the MT6516_mldrn ...... this document
Click eboot select MT6516 - EBOOTNAND this document
Scatter the settings and then turn off the interface. Here, set-on has been completed!
Back to the main screen, press the red circle in the button, the phone off, plug in data cable, press the power button!
After press the power button. Red progress bar began to run, to? 0 will stop for a little while, do not worry!
The second circle blue progress bar go? 0 is completed
The third circle, EB's will fail, ignore it. Remove the machine, press the volume button under the brush card plus Windows key (third from left below) plus power. Will find that card has to brush the Oh!
so sieht innen aus :)
wila
hat sich schon jemand das teil bestellt und ausprobiert ? Bin gerade am überlegen aber das kleine Displ. und die raue Ummantelung halten mich noch ab.
Gibt es schon einen Test ? Die Suche habe ich schon bedient mit T3333.
J
johndebur
ist halt ein günstiges handy, über Verarbeitung kann ich nicht viel sagen, da ich es selbst nicht habe. Ausstattung ist für den preis ok , denke ich.
Das Android teil ist wohl immer noch nicht draußen , ist wohl schwierig mit dem ROM kochen.
Cyberdog
User
@wila
ich habe es letzte Woche bestellt, sollte also in 1-2 Wochen ankommen, dann kann ich dir genaueres sagen. Da es zZt Mondfest in China ist, dauert die Lieferung ein bissl länger.
Cyberdog
a-wei
Also ich habe das teil !!
es ist sehr gut Verarbeitet und es ist Win Mobile 6.5 Drauf in Englisch !
TOM TOM war Vorinstalliert und Funktioniert auch wunderbar !!
NUR
Ich habe schlechten bis Keinen Empfang egal mit welcher Sim Karte ich rein Lege !
Auch nicht mit der Dual Sim Funktion !
ich habe von e-Plus bis t-Mobile alles da aber nix !!
Vieleicht kennt jemand so einen Fehler und kann weiter helfen ??
MFG andy
J
johndebur
vielleicht auf ein ROM update warten. Oder bei irgenteinem handy gabs den trick einfach alufolie zwischen Gehäusedeckel und Akku zu legen und versuchen die Antenne damit zu berühren . Vielleicht hilft das was.
a-wei
Danke für die Antwort aber Leider funzt das auch nicht !!
gibt es so was wie eine Cap Datei die den Empfang verbessert?
oder wo soll man den Rom Update her bekommen ?
MFG andy
J
johndebur
entweder direkt beim händler, besser einmal nachfragen und die mängel schildern. Manchmal tauchen auch englische ROms im netz auf , zB bei den XDA developern.
Dann sollte ja auch mal ein Android ROM rauskommen, vielleicht geht das besser. Chinesische Roms gibts auch, nützt aber wegen der sprache ja nicht viel. Aber konnte jetzt auf mobileuncle auch nicht herauslesen , daß die Antenne probleme macht. Kann ja sein daß die bei dir nicht in ordnung ist.
Wo hast du es denn gekauft?
a-wei
MFG andy
Also ich habe bei MD gekauft und schon dem Assi Ne mail zu kommen lassen !!
aber noch nicht viel gehört !
das Mit Android hört sich gut an !! hoffe das man dann auch mehr darüber erfahren kann !!
Auf alle fälle ist das Handy eigentlich nicht schlecht !!
mfg
J
johndebur
neues vom t3333a , der Android version. scheint so als wäre die Android ROM mal fertig :)
http://www.mobileuncle.com/news/devicenews/2010/1108/3058.html
After a long time in the bounce, T3333a will finally bring the fire version of the Andrews listed the QVGA, T3333a will fire version and the previous t3333 dual card dual standby to keep the same design, but the use of the material is more improved. In a compact size and fine workmanship, the fire version of T3333 will be more outstanding performance I believe.
t3333a in a special resolution, the Andrew system in a variety of interface icons and icons are on, the border is done and is optimized to fit such a resolution. From the practical point of view, Android 2.1 version of the machine running very smooth, while T3333a itself is the key to the design by Android, it's easy to operate on the Android system, experience has a great advantage.
sawfish
