iPDA Wm 7 - ipad alternative?
J
johndebur
was würde denn dagegen sprechen? Kenn mich mit den ganzen chips nicht so aus. Finde ja 600 mhz etwas wenig?
Intelligent Entertainment N2 adopts ARM9 core, 600MHz frequency of the RK2816 processor, equipped with a wealth of Andriod intelligent system applications to meet a variety of intelligence requirements.
J
johndebur
iMito iM7S Weihnachts edition, deswegen in rot, lol :)
Macht sich also gut unterm Weihnachtsbaum:
http://www.shanzhaiji.cn/mobile/20101010/20968.html
800Mhz core iMito iM7S red Christmas Edition Tablet PC unveiled
Holiday arrives, producers began to dress up, dress up and this is Android plate prepared for Christmas, the color changed to red shell and black mix of corners to do the processing, maintenance and im7 the same specifications, Android 2.1 system .
7-inch screen is 800 × 480 touch screen (resistive screen), run the ARM 11 TeleChips 8902 800Mhz processor, integrated 256M DDR2 memory, and 2GB storage space (2G-32G between the optional), supports WIFI, the price of 170 dollars about 1150 yuan.
J
johndebur
Tablet von der Firma ZTE:
ZTE V9 , mit Android 2.1 , 3MP kamera, 7" display (resistiv ), Wifi, 3G etc. Macht nen dünne Eindruck , allerdings steht da daß es erst in RUssland verkauft wird?
Kosten 2000- 3000 yuans.
http://shanzhaiji.cn/mobile/20101012/20999.html
Also sorry that our staff from the ZTE had learned, this item is temporarily not in the domestic market, the aircraft sales in Russia next month, but in the domestic market after the price of 2,000 yuan to 3,000 yuan.
ZTE V9 in the top of the screen design of the front of the front camera and light sensor, because it is standard for 3G WCDMA network support, and has dial-up call feature, so the machine will be front camera for video calls.
We understand that the staff of ZTE, the tablet is used in the resistance of 7-inch screen, it does not support multi-touch, systems, tablet using Android 2.1 version of the system, the end of the year When will a unified upgrade to version 2.2.
J
johndebur
Winpad , vom Design weit aus besser als dieses riesen iphone Ding. :) Wenn dann noch der preis stimmt, nicht schlecht.
mehr Fotos im link:
http://shanzhaiji.cn/mobile/20101013/21017.html
1.66GHz 10.1-inch Tablet PC resolution capacitive screen Winpad
Appearance is very similar with and Apple iPad shape, panel 10-inch LCD screen, the bottom of the aluminum alloy material was built. It appears that the introduction of the X86 shape than ever to be more pretty eye plate number. Machine places the thickest 17mm, is used by the use of a fixed hard drive, the whole machine weighs just 900 grams.
Processor would be more use of special number, using the Intel Atom N455 processor, clocked at 1.66GHz. N455 and N450 of the CPU are basically the same, except that the N455 is used in DDR3 memory, the memory frequency of 1066MHz, DDR2, 800MHz faster than the frequency of upgrading will increase the data transmission frequency several times. And the current price of DDR3 memory than DDR2, replace only a matter of time.
Standard memory is 1G DDR3, hard for the 16G SSD, 10.1-inch LCD capacitive touch screen, standard resolution of 1024x576. The integrated graphics for the Intel GMA3150, the standard 3500mAh battery for about four hours, the machine Windows7 operating system pre-installed.
Support the G-sensor, which automatically rotates the screen and force feedback (vibration of the screen there will be effects by up). Network, integrated Wifi, and support for built-in 3G, because the body outside with a SIM slot. But ordinary users might miss the built-3G module, because you can not install itself. This feature requires customization of the machine, it may have this feature.
J
johndebur
Erfreulliche neuigkeiten übers haipad M701-R. Soll nun mit ANdroid 2.2 funktionieren, noch dazu geht tastatur und maus und man kann damit nun telefonieren.
Ob das die Moonse M701 pads betrifft weiß ich leider nicht. Geht halt um das Pad mit der Fernbedienung ( M701-R ) :
videos im link:
http://shanzhaiben.com/96/n-4696.html
Heiner HiPad new features to support wireless mouse and keyboard and make a call
Heiner HiPad is a 7-inch flat panel Apple imitation, the chip is configured to Telechips TCC8902, 256M memory, 2G/4G FLASH memory, 7-inch resistive touch screen.
Recently released official has several new features, a total of 4 video. One is to upgrade to Android2.2 version of the video presentation is not detailed operation. Another added two new features:
One is an enhanced version of HiPad a built-in wireless receiver, the general market, bought a wireless keyboard and mouse can be used, without need to insert a wireless receiver. This feature can be used together with remote control, watching movies when the LCD is more convenient. Keyboard and mouse receiver distance can reach 4 meters, the sensitivity is good.
Second, you can use a software called HAIPAD PHONE to make a call, you can call the other side of the fixed, mobile phone. Sound can be output through the voice of the plate, built-in microphone. But talk to each other in front Maicon can hear clearly, it is recommended to use an external headset.
J
johndebur
also im video ist ja irgentwas was von cyanogen zu lesen, wohl der ROM bastler.
per baidu kam ich dann hier zu youtube:
[ame="http://www.youtube.com/watch?v=tHrlG2Cx4i4&fmt=22"]YouTube - M701 Android 2.2 CM6[/ame]
M701 Running Android 2.2 CM6...
No ETA on release.
Android 2.2 wird dann wohl hier irgentwo erscheinen:
http://www.slatedroid.com/hsg-x5a-x6-pandawill-g11/4524-[official]-telechips-7-tcc890x-hsg-x5a-x6-pandawill-g11-rooting-hacking-thread-19.html#post72515
J
johndebur
erstes 1:1 ipad Klone mit 9,7" display. Allerdings ist die hardware Müll, 400 Mhz CPU sind wohl vollkommen nutzlos.
Soll aber auch nur 900 yuans kosten.
although the sell price of 999 yuan, but the performance is too low,
Configuration, is the use of VIA 8505 program, based on the ARM9 core clocked at 400MHz, 128M/256M memory (optional), 2G FLASH storage space is Android1.5 system pre-installed, but the UI has been secondary development, interface are to imitate Apple.
http://shanzhaiben.com/99/n-4699.html
_____________________________________________
Hier was besseres Malata Zpad, eigenes DEsign und bessere hardware.
http://shanzhaiben.com/97/n-4697.html
http://www.newpad.cn/archives/414.html
Firmen webpage: http://www.malata.com/en/
First look at its internal armed, using Nvidia (Nvidia) A9's first dual-core mobile processor, clocked at 1GHz. 1G of memory and 16GB FLASH memory, 10.1 inch, 1024x600, capacitive touch screen, with the Android2.2 system also integrates a GPS navigation chip.
This configuration could not help but make people look drooling, and the built-in 3500mAh battery ZPAD, the largest life time can reach 10 hours, performance, extremely powerful, of course, attracted a large crowd of FANS.
Price not officially released in ZPAD when Xiaobian guess, this machine officially listed, is estimated to 3K to win, and sure enough, the official price is 2999 yuan official.
Eric72
Wäre schön, wenn man mal einen Verkaufsstart vom Malata erhalten würde. Das scheint nämlich mal ein gutes Pad zu sein. Bisher hatte ich Apad und Epad und hab beide wieder verkauft....
J
johndebur
Hier noch ein 10" Android tablett. Hat wohl nen Rockchip Prozessor. Sonst nicht viel info, auch kein hersteller name.
http://midbbs.cn/html/xinwendongtai/201010/14-2996.html
10-inch 4:3 flat-rare, and you now know why the Internet will be gone, and now is the era of flat panel support WIFI, with models to support high-GPS, the screen fairly good look at the past and see pages and e-book has a good visual experience, a good control of the thickness of the fuselage, running the Android 2.1, the market price and time is uncertain, but certainly in the future we will use flat as a couch companion.
J
johndebur
Ramos W9 , sieht auch interessant aus :)
Leider stand da kein preis.
http://cn.engadget.com/2010/10/15/ramos-w9-android-hands-on/
Blue Devils not only before the W7, now we see W9 (its also a W11), got my first impression is light, weighing 300g, frame like a smaller version of the iPad, the volume only: 120x195x12.5mm, uses a master Rockchip RK2818, operating faster than the W5 has been a qualitative improvement; 7-inch 800 * 480 resolution LED-backlit display compared provincial point, but lost a bit of brightness, resistance screen design, nice touch operation , 720p HD video, but unfortunately not eat 1080P, we take a closer look at this machine:
This is the interface side, using the Micro USB interface, but also equipped with HDMI, 3.5mm audio interface, and DC charging port.
DDR2 cache capacity of 256M, with the Android 2.1, the speed is good
J
johndebur
aigopad N700 , sieht schick aus :)
Hat einen 7" kapazitiven touch, Wifi , GPS und läuft mit Android.
Steht leider kein preis da.
http://www.shanzhaiji.cn/mobile/20101017/21071.html
Hmm sieht auf der aigo internet Seite ein bißchen anders aus, kann aber auch eine erste grafik von einem prototypen sein. Oder es ist was ganz anderes. Die hardware klingt aber vielversprechend :)
http://www.aigo.com/ProductInformation-858.aspx
Recently, the Patriots released the second generation of electronic tablet aigoPad N700, this section has ten characteristics of tablet PCs: The Android 2.1 operating system, embedded multi-core processors, allowing users to simultaneously carry out multiple tasks become a reality; built-in 512MB memory can experience the 3D games, such as "3D Zombies," "angry bird", etc.; support 3G voice and GPS capabilities, which broke the previous single-function tablet PCs to entertainment-oriented situation, so that more human Tablet PC and practical; combined endurance of 30 days reported, 320 grams of weight, respiratory colorful lights, 7 inch capacitive screen, multi-touch, audio and video entertainment, and fashion in terms of portability, aigoPad N700 has a unique charm.
Hardware von der aigo internet Seite, wenn die beiden N700 die gleiche hardware haben .
aigopad N700
Operating System:
Android 2.1
Memory:
DDR2 512MB 667MHz
Hardware platform:
nViDIA Tegra2-T20
(Dual-core Cortex A9, 1Ghz clock speed, 1MB cache)
Capacity:
4GB/16GB/32GB
Screen size:
7-inch high-definition touch screen
Touch Screen
Support multi-touch screen capacitive sensing
Screen Resolution
16 million colors, resolution (800x480)
Weight:
465g
Dimensions:
208 (mm) x 122 (mm) x 13.95 (mm)
Network Communications:
Network standard
Wi-Fi Bluetooth 2.1,3 G (WCDMA / EVDO / TD-SCDMA standard choose one of three)
Interface:
1 x USB, 1 x MicroSD (maximum support for 32GB), 1x HDMI, standard headphone jack, SIM card slot, docking interfaces
Battery:
3120mAh (1560mAh x 2 cell), 11.5W
Camera:
1300000 webcam
Inductor:
Direction sensors, ambient light sensor
die meisten haben ja leider nur recitiven touch oder? außerdem ist die Batterieleistung für mich ja noch zu gering. Am anfang war ich voll der fan dieser tablets mitlerweile hab ich mir ein netbook gekauft, weil ich denke das die Tablets alle noch nicht so ausgereift sind.
Aber abwarten. Mittlerweile sieht man den Schreibtisch vor Lauter tablets nicht mehr ;)
Loonix
Spokenkieker
Stevenious lies doch mal den post genau vor deinem ^^
Touch Screen
Natürlich muss man vor dem kauf darauf achten und gucken das man das bekommt was man will und jupp, im moment machen die Tablets eine rapide Evolution durch.
Resistive Touches sind inzwischen auch meist sehr gut bedienbar (mein Haipad geht super und ziemlich präziese)
und viele hersteler meiden diese wohl noch wegen des scheinbar relativ hohen einkaufspreises.
