Kennt jemand das CEM202?
nextkoala
Hallo.
Ich hab mir in China das CEM 202 bestellt.
Kennt das Tablet jemand, oder wisst ihr vielleicht ob es ein baugleiches gibt? Mir gehts in aller Vorfreude um Handling und eine nicht allzugrindige Verarbeitung...:p
Daten:
Android 2.1, 10", 1GHZ, 256 Ram, wifi a,b,g micro, g-sensor, 1372g, Preis: $ 206,00 (USD) + EMS
[FONT=Verdana, Arial, Helvetica, sans-serif]Processor Model[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Google Android 1.2[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]CPU[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]1 GHz[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]RAM[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]256.[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Memory [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]microSD, expandable up to 32GB[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Display Size [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]10 inches[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Link [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]802.11a/b/g Wi-Fi[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Audio [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]MP3.WAV[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Video[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]RMVB.FLV.MP4.3GP.AVI[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Microphone[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]installed[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Supported image formats [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]JPG, GIF, PNG[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Supported e-book formats [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Word, Excel, PPT, PDF, TXT, HTML, DOC[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]G-Sensor [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Yes[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Bundled Software[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Map, MSN, Skype, email, Brower, alarm clock, games, Livo Recorde[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Menu language to [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]German, English, French, Turkish, Italian, a total of 150 languages[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Dimensions [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]230mmx178mmx12mm[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Accumulator[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Fixed[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Color [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Black[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Weight [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]1372g[/FONT]​
Gruss
nextkoala
nextkoala
Handling gut? Gibt der Touchscreen beim Tippen nach, oder ist er starr?
Gibts Updatmöglichkeit auf 2.2, daß dann auch Flash geht?
Sind die FW Updates einfach zu machen (Treiber und so...) oder besser die Finger davon lassen. Sorry wegen der vielen Fragen, aber ich bin ein absoluter Android Dau....
allan
wenn ich les baugleich zenithink und andere dann wird es mir schon schwindlig wenn ich dieses und andere foren durchlese...ich will dir keine angst machen aber sei froh wenn das ding zumindest in den grundfunktionen funktioniert....drücke dir aber die daumen!!
