iPDA Wm 7 - ipad alternative?
J
johndebur
A8 tablet mit Android 2.1 , soll mal Android 2.2 bekommen.
Hat 800Mhz. Allerdings sollen die Nachfolger chips 1ghz haben, also soll man besser warten bis der chip zur Verfügung steht um verbastelt zu werden. :)
http://shanzhaiji.cn/mobile/20100809/19253.html
http://www.shanzhaiji.com/info/201008/09-10281.html
Das tablet sieht aber rein äußerlich ganz nett aus. Blöd nur , daß so tablets so wenig Speicher haben.
An 8-inch Tablet PC, and Apple looks similar to the main chip used for the Freescale MX515, based on Cortex-A8 core, clocked at 800Mhz.
At present this 8-inch flat was in the Android2.1 system, when the official release, you can match the Android2.2 system. The Android version, the more need for powerful hardware performance, no doubt A8 core chip, and Android2.2 version will be the best combination.
Freescale music imx51 series, clocked at 800MHz, if you need really to 1GHz, we must wait until imx53 the only chip yet listed.
This 8-inch imitation apples, the maximum support 512M RAM, is different is that it does not have built-in FLASH memory chips, the direct use of external plug TF card to store data, TF maximum support to the 16GB. Used 8-inch TFT resistive touch screen with a resolution of 800x480. Is 16:9 specifications, Xiao Bian still hope that we can be on the resolution to 1024x768, or 1024x600, this page will look and feel as the computer, web pages will not shrink or need the left and right drag.
Using a dual-battery inside, 3.7V, 2 combined capacity is 5000mAh, endurance capacity without actually tested, so a large-capacity batteries, guess 4-5 hours should be no problem. If users in Shenzhen, you can experience the prototype site. Field users wait patiently it is expected by the end of August to September, you can see the products of mass production.
J
johndebur
noch ein Android 2.1 pad. ist von der Firma 金迪奥 , lol Google übersetzt das mit "Quindio".
naja egal. ist im moment noch prototyp. Leider haben all die pads nicht sehr viel Speicher. Da bring ich ja nie meine Fotosammlung unter :hahaha:
http://shanzhaiben.com/22/n-4622.html
Tell us about the specifications of this imitation iPad, the screen is 7 inch TFT with resistive screen, 16:9,800 x480 resolution
Shenzhen, China recently introduced as a light look a bit like iPad tablet PCs, using the Korean Telechips8902 program, the master chip to 800MHz, based on the ARM11 core.
Others, using 256M DDR memory and 4GB FLASH memory, by TF card, can support a maximum 16GB. In addition, the camera body provides a Mini USB slot and the HDMI slot.
Software, powered by the Android2.1 system. In addition, Telechips video processing chip in more, to support the 1080P movies. In fact, only such a small storage space, such a small screen, watching movies is a 1080P high-definition hype gimmick. However, can play 1080P, proved stronger than those who can not support hardware products.
J
johndebur
neue Bilder vom TESO Lpad. hat nun Apple logo, der preis steht leider noch nicht fest. macht aber nen hochwertigen EIndruck
http://www.midbbs.cn/html/MIDchangshangzixun/2010/0808/2600.html
参数:
rocessorandCorelogic mid爱好者之家
CPU:IntelN4551.66GHz/512K/SingleCore/GFX200MHz/TDP6.5W
CoreLogic:IntelNM10ExpressChipset
Display
•IntelGeneration3.5IntegratedGMA3150(133MHz)
•10.1screen16:9inchTFTLCD(1024*768)
•TTLInterfaceCapacitiveTouchPanel
SystemMemory
•SupportDDR31333MHz
•OneSO-DIMMslotsupportupto2GBmomory
Storage:
•Support8G/16G/32GSSD(SATAinterface)
•SupportCardreader,Micro-SD
KeyboardandPointingDevice
•Nokeyboard
•SupportSingle/MultiCapacityTouchscreen
I/OPorts
•Audioport:OneJack(Headphoneout&BuiltinMICin)
•USBport:TwoUSB2.0Ports
•Powerport:OneDC-InPort
•VideoPort:OneMini-VGAPort
Slot
•SIMCard:One
•CardReader:MicroSD
PowerSystem
•BatteryLi-PolymerPack,10.8V/4200Amh(35Wh)Batterylife:4hrs~5hrs
•110~240V,DC19V2.1A@40WACAdapter
PowerManagement
•ACPIV2.0
•S0,S3,S4,S5support
Cardreader
•Cardreader:MicroSD
SwitchControl
•PowerOn/OffSwitch
•WirelessButtonSwitch
•KBButtonOn/OffSwitch
OptionItems
•Bluetooth:V2.1+EDRWIFI:8012.b/n/g
•3G:/TD-SCDMA+CMMBorWCDMA
•Styluspen(toolingreserve)
Feature
•OneMiniPCI-Einterface,2Antenna,Support802.11B/G/N,HalfSize(SDIO)
•Audio:HDAudio,Built-In2Speaker(InternalMicrophone)(1.5W*2)
•G-sensor:Visualrotation
•Camera:1.3MPixels(onlyfrontsideforvideo)
LEDIndication
•PowerLED
•BatteryChargeLED
•WirelessLED
Certification
•CCC
OS:SupportWindows7,Meego
WeightandDimension
•275×170×14mm
•N/W:725g(includingRAM,SSD,Batterypack)
kein-clone
"Apple-Jünger"
Also das TESO Lpad sieht echt am besten aus. Liegt aber daran das die das Design direkt geklaut haben. Also wenn es nicht das original ist, würde ich auf den Apfel verzichten. Finde diese Clone extrem arm.
Ich werde mir dieses Jahr mit Sicherheit auch noch ein iPad kaufen. Da weiß ich wenigsten was ich habe und wo ich hingehe bei Problemen. Finde auch 499 Euro für die 16GB Version nicht so teuer. UMTS brauche ich nicht, kann ja tethering übers iPhone.
J
johndebur
ja das apfel logo könnten sie echt weglassen.
16 GB speicher wären mir zu wenig. Denn das ipad ist prima als Fotoalbum , fotos draufkopieren und man kann prima durch seine Fotosammlung browsen. Denn am PC schaut man sich die Bilder eh nie an. :)
Dafür ist das ipad echt prima. Aber da braucht man dann auch etwas mehr Speicher und dann wird es viel zu teuer. Die Spiele interessieren mich eh nicht. Da hab ich ja den PC. :)
naja mal sehen was das teil kosten soll. zum Schluß kostet es dann so viel wie ein ipad wenn man es importiert.
kein-clone
"Apple-Jünger"
@ johndebur
Ja das wäre natürlich nen Ding wenn es so teuer wäre. Denke ich aber nicht.
Ich spiele sehr viele Apps, deswegen ist es für mich mit dem Appstore ein großer Vorteil! Dann noch nen Jailbreak drauf... Fotos sind für mich nicht so wichtig. 16GB sind auch noch 16GB.
Aber da ist ja auch jeder anders mit dem Umgang von so nem Teil!
J
johndebur
erstes kapazitives shanzai tablet? . naja hat zumindest ein 10.1 " kapazitiven touchscreen und läuft mit Windows 7.
endlich mal genug speicher :) gefällt m ir mal sehen wie der preis sein wird.
http://www.shanzai.com/index.php/bandit-gadgets/tablets/1596
http://digi.tech.qq.com/a/20100809/001012.htm
Processor Model - Intel Atom N450
RAM - 1GB DDR3
Hard Disk - 250GB
Graphics - Intel GMA 3150
Screen - 10.1 inches capcitive
Screen Resolution - 1366 x 768 pixels
Weight - 0.99 KG
Dimensions - 170mm x 16.5mm x 22mm
Wireless LAN - 802.11b/g/n wireless protocol
Ethernet - 100Mbps network card
USB - 2 × USB2.0
Card Reader - SD, SIM card optional
Video Output - VGA & HDMI
Audio - headphone out, microphone in
Battery Type - 6-cell lithium battery
OS - Windows 7 Home Basic
There's no concrete pricing info just yet. Expect the KUPA to be available sometime in mid-September.
__________________________
dann noch was übers WITS A81. Wird von den shanzai typen empfohlen
bericht und video:
http://www.shanzai.com/index.php/bandit-gadgets/tablets/1595
While the device is not perfect its absolutely the best performing tablet we’ve seen from the shanzhai players thus far and it sells for under USD 200.
Purzelkater
Hm, sieht außerlich und von der Ausstattung dem AZ01-H01
doch sehr ähnlich, nur dass dieses ein 10" resistive multitouch panel hat. Reizen würde es micht ja schon, das gebe ich zu. Aber rund 480 Euro (Gerät+Versand+MwSt, wenn ich mich nicht verrechnet habe) sind schon eine Menge für ein solches Paket aus China. :unsure:
Ein Win7-Tablet mit kapazitivem Touchscreen habe ich bis jetzt nur bei Pandawill als MTP05 entdeckt.
J
johndebur
noch ein windows tablet. sieht aus wie das von TESO oder eben das MTP05 , aber scheint was neues zu sein. Hat schon mal kapazitiven touch und 3G. :)
Google übersetzt den Firmennamen mit "Shun Ericsson" , auf dem tablet steht aber irgentwie was anderes, "AOSON" wenn ich das richtig entziffern kann.
also hier das  爱立顺R116 , Shun Ericsson R116:
http://www.shanzhaiji.cn/mobile/20100812/19307.html
oder:
http://www.pcolive.com/article/201005/18/834754.shtml
Ericsson has a 10.2-inch screen along, looked like a large of the iPhone, edges smooth, reflecting the strong sense of fashion, the thickness is also well maintained, highly integrated chipset with the Nokia N96 makes the R116 products thickness of not more than .
R116's screen resolution 1024 * 600, both display images or video playback are very delicate.
Including power switch, a power cord jack, 3 USB, a headphone jack, an HDMI HD output interface, a wireless network card slot, a SIM card slot and a volume button.
Ericsson R116 along with the Intel dual-core processor N450, Intel GMA3150 graphics, design with DDR2 800/667 MHz memory, the largest to support to 2GB, with NM10 Intel chipset. R116 uses a resolution of 1024 * 600 10.1-inch LED screen capacitance to support multi-touch support the 802.11B / G wireless card, also has the function of today's most popular 3G, 3000 mAh Li-ion battery life of 4 to R116 hours, together with only the thickness of 20MM, 1.2Kg weight.
Shun Ericsson R116 comes with windows 7 Ultimate operating system, very easy to use. Shun Ericsson R116 also joined the G-Sensor gravity sensing system,
ach ja die kosten 3700 yuans: ( woanders auch als 3300 yuans gelistet )
hmm denke es gibt verschiedene versionen, mit linux oder windows, bei pconline kostet es 3900yuans, hat aber auch 320gb Speicher
http://product.pconline.com.cn/tabletpc/aoson/415987.html
http://detail.zol.com.cn/umpc_mid/index243308.shtml
J
johndebur
ja mir auch :) ist halt schön kompakt und handlich, das andere sind dann doch eher dicke laptops ohne tastatur.
J
johndebur
EKING M5 , ist glaub ich die Firma die auch das XPphone gemacht hat.
Naja die bringen jetzt ein tablet heraus, mit sliding keyboard.
http://price.zol.com.cn/191/1912830.html
sieht noch nach Konzept aus. Anscheinend kann man mit dem tablet telefonieren, macht sich sicher toll , wenn man es ans Ohr legt :crazy:
EKING M5 with Intel ATOM Z515 processor, clocked at up to 1.2GHZ, 1G memory, 16G SSD high-speed hard drive, support for Windows XP/VISTA/7 operating system that supports multi-tasking operations, performance, far more than the processor with 1GHz A4 iPad.
In appearance terms, EKING M5 was cool black, noble and generous, surface grinding treatment, work very good. To facilitate the operation, particularly user-friendly in the stock, when using online banking password, EKING M5 with full keyboard, slider design. Will push the slide back, as if that is a Tablet PC, and is the world's first processors to use Intel ATOM Z515 Tablet PC.
EKING M5 weighs only 438 grams with battery, the size of the combined equivalent of 100 yuan, is very portable. 5-inch WSVGA widescreen. Display is a Sharp original imported LED display with a resolution up to 1024 * 600, is currently the highest resolution of the MID. Support multi-touch touch screen, to the user good working experience.
EKING M5 were to support China Mobile TD-SCDMA, WCDMA and China Unicom, China Telecom EVDO high-speed 3G network, users can enjoy high-speed Internet access anytime, anywhere fun. With previous EKING, VILIV series, like MID, EKING M5 also support 3G calls and send and receive text messages, set the computer functions and the functions of a cell phone. In addition, WIFI and Bluetooth support for wireless Internet access.
EKING M5 with GPS function, users can install the spiritual Figure 9, and other navigation software, car owners can use as navigator.
EKING M5
Product Type Tablet PC
OS Windows XP Home
Processor type Intel Atom Z515
1200 GHz processor
Motherboard Chipset Intel US15W
1GB memory capacity
Memory type DDRII
16GB hard drive capacity
SSD Solid State disk drive description
Screen Size 5
1024 × 600 screen resolution
Type of integrated graphics card
Intel GMA 500 graphics chip
Camera integrated 300,000 pixel camera
Wireless network card supports 802.11b / g wireless protocol
3G Internet access ports reserved for 3G Module
Description Integrated LAN card
SuperSpeMo
wie ,Xphone?dann muss das ding ne nukleare Batterie haben,und kann Strom in allen Stromstärken bereitstellen.
Nene ,OT beiseite,winXP gehört für mich nicht darauf.Und die CPU könnte auch besser sein.
EDIT: Oh gott,lesen sollte man.Du meinstest das XP phone...Das ist natürlich anders.
Buldog
Die CPU könnte besser sein?
1200 GHz processor - wow. ich kenne nur 1,2 ghz also die leistung sollte doch locker reichen :p
J
johndebur
Hmm kligt interessant, ein pad das unter anderem mit hackintosh laufen kann . Wird zwar von der herstellerfirma nicht empfohlen, wegen License Abkommen, aber klingt ja trotzdem nett :)
allerding nur resistiver touch
http://www.crunchgear.com/2010/08/12/axon-logic-hackintosh-tablet-may-just-out-ipad-the-ipad/
http://www.axon-logic.com/
Keep in mind that much of this hardware is user-replaceable.
  • 1.6GHz Atom N270 (other trims will be available)
  • 10″ 1024×600 LED-backlit LCD
  • Resistive touchscreen w/ built-in stylus
  • 2 200-pin SO-DIMM slots (2GB standard)
  • 2.5″ HDD bay (320GB standard)
  • 1.3MP webcam
  • Wi-Fi (A/B/G/N)
  • 3G SIM slot (AT&T or Verizon)
  • Built-in speaker
  • 3x USB, Headphone, mic, ethernet, VGA ports, card reader
  • On-screen keyboard and handwriting recognition
  • Removable battery (3000mAh, ~3hrs)
  • 0.9kg (just under 2lb)
Basically you’re looking at a slightly overachieving netbook. Impressive in some ways, disappointing in others. The cost will be $800, or $750 if you get into the beta.
