SUNNO Q880 Rom update
api29
[Quote = Petteri , 236 965 ] Mit akarsz ? A ROM-ot , vagy segít , hogyan lehet rugalmas a Sunno ? [ / quote ]
I want ROM (6.5) and updater program+usb driver.
The hardreset not help!!!
api29
Ok Thank!!!The program is running!!!
The program is running,but not good the img file,in rar pack
Q880_Sunno_11-??.bin <---this format is a problem!!!(??)
Rename?
not running
Yes, try to rename it. It could be a problem because it has some Chinese charcters in the name.
This is for a DIFFERENT phone but the flashing process is the same, maybe it'll help as well:
[ame="http://www.youtube.com/watch?v=-DaHt3OLUos"]YouTube- Sunno Yota Max4G ROM Update - A Merimobiles.com Techtip[/ame]
That's definitely not normal :(
Is you phone still working anyway? Do you get a signal with your service provider, can you make calls?
I WISH I knew how to get into the "engineer mode" of that phone because then I might have a solution for your IMEI problem. Unfortunately I don't have the slightest clue about how to activate the engineer mode of that phone :(
