Neue FW I9+++ vom 17.03.2010 und wieder neue Codes
Sander
Hallo, ich dachte ich lass euch mal teilhaben an meinen neuen Foruschen. :)
Hab grad einen Readback meines I9+++ gemacht das die bis jetzt wohl neuste FW vom 17.03.2010 hat, und natürlich auch wieder neue Codes.
Hier der DL Link zur FW(Danke COlonel): Klick
CPU: MTK
File size: 32 Mb
ROM: X2501G_HW.2501G_0B_4455_ALL_V1_3R--100317.BIN
BUILD: GEMINI 2501G_0B_4455_ALL_V1.3R X2501G_HW 2010/03/17 22:31
[MCU SW] 2501G_0B_4455_ALL_V1.3R
FS(fat) - Start: 0x1E00000, Size: 0x200000
--- Languages --------------
*#0044# |en-US| English
*#0033# |fr-FR| Français
*#0034# |es-ES| Español
*#0048# |pl| polski
*#0351# |pt-PT| Português
*#0039# |it-IT| Italiano
*#0049# |de-DE| Deutsch
*#0060# |ms-MY| Bahasa Melayu
*#0062# |id-ID| Bahasa Indonesia
*#0420# |cs-CZ| Czech
*#0031# |nl-NL| Dutch
*#0084# |vi-VN| Ti?ng Vi?t
*#0090# |tr-TR| Türkçe
*#0007# |ru-RU| ??????? ????
*#0966# |ar-SA| ???????
*#0098# |ps-IR| Persian
*#0066# |th-TH| ???
*#0886# |zh-TW| ????
*#0086# |zh-CN| ????
--- LCD driver --------------
lcd_main_ili9320_8bit.c
lcd_main_ili9325_8bit.c
lcd_main_ili9328_8bit.c
lcd_main_un8999_8bit.c
--- SpeedDial codes ---------
*#0000# Auto language
*#0044# Set English language
*#0886#
*#0034# Set Spanish language
*#0048# Set Polish language
*#0033# Set French language
*#0049# Set German language
*#0039# Set Italian language
*#0066#
*#0007# Set Russian language
*#0351# Set Portuguese language
*#0090#
*#0084#
*#0062#
*#0420# Set Czech language
*#0060#
*#0031#
*#0966#
*#0098#
*#0086#
*#06# Show the IMEI
*#9438375# Service
*#9433646633# Service
*#94366*# Service
*#94387# Service
*#94333778# Service
*#943523# Service
*#943678# Service
*#943876# Service
*#9436810# NICHT EINGEBEN - DANACH GEHEN KEINE CODES MEHR!!!
*#1234# Set A2DP Mode
*#900# BT Power ON
*#901# BT Power OFF
*#902#
*#903#
*#943251# Service
*#943250# Service
*#520520*# Service
*#77773# Service
*#77776# Service
*#9433366*# Service
*#422789# Service
das wäre intressant zu wissen, spiele auch mit dem gedanken eine andere firm drauf zu machen
Nur so zur Info,
dazu braucht ihr ein spezielles Flashkabel.
Mit dem normalen Datenkabel geht das nicht.
Flashvorgang ist so, 2. Video für NOR-Flash: click
Und die meisten Firmwares sind nicht kompatibel.
D.h. die Chance das die neue auf eurem I9 läuft ist nahezu null :(
Da ist eher das modden eurer eigenen angesagt. Macht aber auch Laune :)
Grüße
Sander
Okok, ganz langsam.
Ich hab die FW hochgeladen damit Ihr was zum Spielen habt. ;-)
Bitte nicht gleich jeder Neuling diese FW draufhauen und dann maulen dass das Handy nicht mehr geht.
WICHTIG!
Erstmal braucht ihr, wie RUmpel sagt, ein Flashkabel. NICHT das Datenkabel.
Dann unbedingt die eigene FW sichern, sprich Readback machen!
Dann könnt ihr wenn ihr wollt die FW testen ob sie bei euch läuft.
Wenn sie nicht läuft eure eigene wieder aufspielen.
Zum Thema was es bringt:
Normalerweise bedeutet neuere FW meist immer verbesserung, was aber bei China CLones nicht unbedingt sein muß. Deshalb nicht gleich drauflos Flashen sonder ERST im Forum INFORMIEREN was passieren kann und welche Risiken das Flashen hat!
pablojose31
Und mal wieder ich mit ner bescheidenen Frage :)
Welche Flashtool Version haste dazu benutzt?
Meine schmeisst mir ständig ne Fehlermeldung ...
MFG
Sander
Deine fehlermeldung sieht nach nem neueren NOR aus.
Die bekomm ich auch bei meinem 2010er Model.
Diese FW war auf einem 2009er Model dessen NOR wohl unterstützt wird.
Zur eigentlichen Frage: Die aktuellste vers. aus dem DL bereich.
Wird aber nicht gehen wenn du ein 2010er Handy Model hast, auch wenn da die FW wohl etwas älter ist scheint der NOR Typ neuer zu sein.
So ganz hab ichs auch nicht kapiert aber ich muß auch noch auf eine neuere vers. warten um mein 2010er Model auslesen zu können.
anidri
ja aber wo kann man das runterladen ob gute oder schlechte übersetzung wo genau? ich habe ein i9+++
