Getting Java applications installed on the Pinphone
lubis
Pinphone Java apps in main screen... Possible?
Hi there!
I just got my new Pinphone and have been surfing around to see how to install Java applications on the phone.
What I could see is that the java apps are installed inside the Games folder? Is that correct? Is not possible to see the Java apps that you install in the main icons screen of the phone? Like it happens in the original iphone?
Thanks and Regards
lubis
Hi Colonel!
It has to be a way to do it.. maybe editing some file? I am sure there has to be a way...
I saw a video on youtube in which somebody could access bolt through the opera icon in the main screen... if he was able to do that for sure it will be possible to replace the icon someway...
to be a proper iphone clon that should be able to be possible... sooner or later we will get the way..
Hi Colonel!
Hi :)
I wrote ADD or REMOVE, I didn't write EDIT ;)
Once we are able to flash this phone, we will also be able to REPLACE some icons in the firmware but never ever will we be able to add EXTRA icons or remove any icons for good.
closebor
