Wo bekomme ich für mein 3GS die Firmware her ? ebenfalls Spiele !!!
Ich habe von dem Phone noch nirgendwo eine FW gefunden und den Pinout um sich ein Flashkabel zu basteln, habe ich ebenfalls noch NIE gesehen.
filewalker1
Du hast nicht Pech gehabt. Die mit v005 haben Pech gehabt. Bei denen funktioniert der G-Sensort nicht mher in den java apps.
Warum das so ist weiß ich auch nciiht, ich kanns nicht nachvollziehen und finds einfach schade, da das handy sonst gut ist
jadran
Hi! first hello to everyone, sorry for mine bad english I am croat.
Pins for this phone are
17 - RX
19 - TX
30 - GND
I had a firmware V007 but phone bricked because of mine bad using it first time(NOR/NAND), phone was dead and there was no hard reset button.
Cleaning of memory did't help
And backup is bad because battery went off in the half of process and the backup is garbage, I did't check it with hex edit before doing a reflash because I was thinking that will make him alive.
FW files I found are here:
http://forum.china-iphone.ru.for-test-only.ru/viewtopic.php?f=8&t=23&sid=d6d25f6abd5567589b4153da93a62eff
Hope this all helps some one.
17 - RX
19 - TX
30 - GND
Are you sure???
We talk about the Efox 3GS.
And the Rx pin doesn´t seems to be connected to the plug.
We found out: 18-Tx, 30-GND.
But never found the Rx
Also from another forum we got that replay:
Search showed that the contacts for the update firmware is not connected to an external connector. Therefore used to connect directly to the mainboard.
So the only way to flash that phone ist using the onboard pins :(
And your problem:
when you get an error while making the readback before it´s finished, you must disconnect the battery for a few seconds.
After that the phone should start again :)
Hope that will help.
jadran
Rumpelstilzchen;
mine does not have any label, only on back there is apple logo, even under battery there is nothing, so maybe I am wrong, sorry for misunderstand. I saw mine firmware was like:
F35W cld 240 320 IFI V007, so i thought it is the same, stupid me.
After bad readback; i left the battery off the mobile whole day and it did"t help.
If some one has or know a FW with above numbers and letters please post a download link.
All i have are imei numbers I wrote down on a peace of paper,
EDIT: Now I tried couple of firmwares witch begin with F35W and all are gaving me white screen.
EDIT2: And yes! U are right i found a selling chinese site with a video and IMEI numbers and mine phone is hiphone/sciphone pk168. So i will not post here and make garbage in wrong topic.
I can delete all post in here if necessary.
