Meizu MX3 - 5,1 display ( 1920 x 1200 p) Samsung Orion 5410 Octacore ????
Manu-M3
Meizu Fanboy
Bin ist eben die chinesische FW Version.
Dachte es geht nur mit der .bin ohne Recovery.
Aber ich finde die CN FW eh besser ;)
djvs
Gametot
Flyme 3.3.1 for MX3 released
https://www.dropbox.com/s/ubsswbawkzt34pn/update.bin
Changelog:
[Camera and Gallery]
New Lytro Light Field Camera settings, with the "shoot first and focus later" feature
Added 12 new set of real-time video filters
Optimized video size, reducing it to a quarter of previous size
Added 1.5 second long exposure
Added after the event, photos automatically sets of functions
Added when taking a picture, double-tap on the screen to activate the composition lines
New two finger pinch-to-zoom in video capture
Added night mode for camera
Optimized flash photography effect
Modified the settings bar interface
[Music]
New cloud sync playlist feature, login Flyme account, you can find local and online songs
Added "Match high quality" feature, which can instantly match locally stored songs to the lossless quality/high quality versions online
New when downloading songs, automatically downloads the lyrics
Added global sliding menu functionality, users may at any time call out sliding menus, reducing page jumps
Added "My Favorites" to locally stored songs
Modified "search" function to the Home page
[WiFi]
Optimized the 5GHz WIFI network speed
Fixed cannot connect laptop portable hotspot issues
Fixed bluetooth cannot connect to some issues of vehicle equipment
[Contacts]
Optimized the accuracy optimizing contact merge
Fixed Google account contact sync problems
Updated mobile phone number belonging to the database
[Find handset]
Optimized remote picture transmission speeds, photos will upload after compression
Fixed some cases, failed to find cell phone network problem
[Desktop]
New allow infinite folders and icons number of infinite extensions, icons, scroll up or down
New built-in AliPay application
[SMS]
Modified the SMS popup display policy, after users click on the popup will disappear
[Documents]
New document search functions, supporting pictures, music and other types of searches
New document encryption compression features
Fixed "unshare a folder is invalid" problem
[Browser]
New Web drop down hover featuressite
Added page hits, such as telephone, mail, automatic pop-up options menu
New link to copy features
[Mail]
New Mailer's address bar enter "@", the system will automatically complete the email suffix
Added slide list; folding displays the mailbox account function
[NFC]
Optimized the NFC pairing success rate
Optimized the NFC tags function
[App Center]
Modified the Application Center notice bar display policy; multiple notifications will merge
[Video]
Added image-scaling memory function; without using the back exit video programs and without shutdown, when entering the video again, according to the previous screen ratio play
[Input method]
Upgraded Xunfei speech input engine; improved speech input experience
[Calculator]
Added landscape mode
[OTA]
Modified push OTA policy; rooted devices will now only be able to receive the entire firmware package
J
johndebur
Ab 27.12. wird das MX3 um 200 yuans billiger . (25€)
魅族MX3大降价! mydrivers
Meizu MX3 great price!
Meizu has just announced that starting December 27, the full range of Meizu MX3 (WCDMA version of the TD version) handset prices down, price 200 yuan, 16G/32G/64G/128G version priced at 2199 yuan / 2399 yuan / 2799 yuan / 3799 yuan. With immediate effect, the user can be purchased at 600 stores nationwide channels Meizu, Meizu Meizu's official website online store and flagship stores such as Lynx.
Meizu MX3 is this new release of its flagship phone with 5.1 inches using New Mode 2 screen resolution of 1800 * 1080 pixel density of 415PPI, equipped with 1.6GHz frequency Samsung Exynos5410 eight-core processor with 2GB of memory, storage capacity has 16G/32G/64G/128G optional.
In addition, it provides 2400mAh battery provides 8-megapixel back-illuminated camera, F/2.0 large aperture, the front camera is 2.0 megapixel. In addition to the regular edition, Meizu also provides a pure white version, and TD version of the user.
Ausgelebt
Outfluencer
Wenn ich über WhatsApp ein Foto aufnehme und dies verschicke, werden die Bilder auf dem Handy gespeichert. Ich kriege die in der Gallery aber nicht angezeigt. Bei allen anderen Android-Handys wurden die immer in einem extra Ordner in der Gallerie angezeigt, hat jemand eine Ahnung wie das bei dem MX3 ist? (Kann ich das irgendwie ändern, dass das wieder so ist)
Kann ja in der Gallery Ordner auf dem Speicher auswählen und hinzufügen, jedoch ist der Ordner Whatsapp->Media->WhatsappImages leer.
J
johndebur
hmmm da ich whatsapp nicht nutze kann ich nicht viel zu sagen. Allerdings habe ich mir die Google gallery apk installiert, damit auch das Picasa Webalbum synchronisiert wird. Vielleicht geht es damit auch, denn das zeigt alles an :)
J
johndebur
nee glaube ist für Android 4.2 ohne diese Photosphere und Kamera. Gallery 1.1.30682 um genau zu sein. Hatte ich schon bei meinem alten Handy drauf.
Die mit der photosphere ging bei mir auch nicht. Kann ich ja irgendwo hochladen , wenn du möchtest
Manu-M3
Meizu Fanboy
Du kannst in der Meizu Galerie einfach auf + und den Whatsapp Ordner hinzufügen.
Ganz easy:)
Der Whatsapp Ordner kann eig nicht leer sein;)
Bei mir gehts auch!
Ausgelebt
Outfluencer
Bei mir ist der Whatsappordner komplett leer. Wenn ich ihn anklicke und hinzufügen will passiert nichts. Wenn ich jedoch in Whatsapp auf die Büroklammer klicke zeigt er mir die ganzen Bilder an..
dierose
Hast bestimmt eine versteckte .nomedia im Ordner.
Das verhindert das Anzeigen von Medien.
Kannst Du entweder am PC sehen oder im Deinem Datei-Explorer in den Einstellungen anzeigen lassen. Dann siehst Du die bzw kannst die löschen.
djvs
Gametot
Habt ihr eigentlich auch bei manchen Apps/Games Soundprobleme?
Habe diese zb. bei Play Movies, Rayman Fiesta und jetzt aktuell bei The Cave
J
johndebur
Play Movies geht bei mir auch nicht, dachte das liegt an der app. Da rauscht der Ton einfach nur. Rayman und the cave kenn ich jetzt nicht, ansonsten hab ich noch keine Tonprobleme bemerkt
djvs
Gametot
Bei Rayman und The Cave ist es nicht so schlimm aber man merkt es halt.
Bei Rayman sind die Soundprobleme auch erst seid eine Update da vorher war es normal.
J
johndebur
habe bis her dieses play movies auch noch nicht genutzt. An Weihnachten waren zwei kostenlose Filme im Angebot, da wolllte ich es mal ausprobieren. Aber beide Filme rauschen nur, ob das dann bei jedem Film so ist weiß ich nicht.
Vielleicht wird das ja mit dem nächsten Flyme update gelöst?
Ausgelebt
Outfluencer
Frohes Neues an euch und habe heute eine ziemliche "Noobfrage". Wie schaffe ich es denn bei dem Musicplayer Repeat, Zufall usw einzustellen? :X
