Xiaomi Mi 4i / Mi4i Review - 64-Bit Snapdragon 615 Octa Core - Dualsim LTE - ColonelZap
Review Video:
Daten:
5" inch capacitive 10-Point Multi Touch Screen
Display 1080x1920 pixel resolution - Full HD Display, IPS, OGS, Sharp / JDI , Gorilla Glass, Sunlight Display Technology, 441 PPI
2nd Generation Qualcomm Snapdragon 615 64-bit Octa-Core processor, 4x 1.7 GHz, 4x 1.1GHz
GPU: Adreno 405
Android 5.0.2 Lollipop with MiUi V6 on top.
2GB RAM / 16GB of internal memory - no TF-card support
Quadband, unlocked, 3G / UMTS / HSDPA+ / WCDMA / 4G LTE
2G GSM - 850/900/1800/1900MHz
3G WCDMA - 850/ 900/1900/2100MHz
3G TD-SCDMA - 1900/2000MHz
4G FDD-LTE B3/B7 - 1800/2600MHz
4G TD-LTE B38/B39/B40/B41
Wifi, Bluetooth, GPS, A-GPS, GLONASS & BEIDOU, g-sensor, proximity sensor, light sensor, magnetic field sensor, gyroscope sensor, hall sensor, multi color notification LED
OTG - USB on the go
Build in battery 3120mAh
Anti-grease coated back cover
Main camera: 13 MP output, autofocus, Dual LED / Dual Color flash, 1080p video recording, F2.0
Front camera: 5MP output, F1.8
Dual Sim - Dual Standby (two micro sim cards)
Weight: 126 g / 7,7 mm thick
Von hier: http://www.honorbuy.com/57-xiaomi-mi-4i
Kamera Testbilder hier: http://colonelzap.blogspot.de/2015/06/xiaomi-mi-4i-mi4i-review-64-bit.html
Screenshot_2015-06-15-15-47-32.png Screenshot_2015-06-15-16-23-06.png Screenshot_2015-06-15-16-49-40.png Screenshot_2015-06-15-16-54-36.png Screenshot_2015-06-15-16-57-09.png Screenshot_2015-06-15-16-58-09.png Screenshot_2015-06-15-16-58-27.png Screenshot_2015-06-16-08-58-20.png weigt.jpgmi4i_4.jpg
