Hey guys, this is the UMi Plus E Review, the cheapest phone with 6GB of RAM! I really like the UMi Plus E and while it is a good phone, it faces stiff competition from others. So the "E" in the UMi Plus E stands for "Extreme", making the name a rather long UMi Plus Extreme, so I (and pretty much everyone else) has shortened it to just UMi Plus E. UMi Plus E Specifications: Mediatek Helio P20 MTK6757 Octacore Processor 5.5" 1920x1080 IPS LCD 6GB/64GB Android 6.0 Marshmallow 13MP/5MP Camera (4K capable) 4000mAh Battery 185g, 15.60 x 7.60 x 0.91 cm Let me know what you think about the UMi Plus E in the comments down below!
Awesome review again, got to run so I'll have to watch it later. Can you tell me one short detail? Do you need to use the Onscreen buttons or does the UMi have a one in all homebutton like the ZuK or so? And does the notification LED also do mix colors like purple and white (so not only RGB, but mixes of them)?
No there are actually 2 capacitive buttons beside the home button that you can use. the Home button is a regular button. the Notification LED is only RGB I believe, never seen it anything else. Did Chinamobilemag do a full review of this phone? Or was it an unboxing?
Do they light up in any way? That is actually good that it has a regular homebutton and two other buttons
