Review Video:
Daten:
5.5" inch capacitive 5-Point Multi Touch Screen
Display 720x1280 pixel resolution - HD Display, IPS, OGS (?), Gorilla Glass (?)
MTK6752 64 bit Octa-Core SOC @1.7GHz
GPU: Mali-T760
Android 5.0 Lollipop
3GB RAM / 16GB of internal memory - TF-card support
Quadband, unlocked, 3G / UMTS / HSDPA+ / WCDMA / 4G LTE
2G GSM - 850/900/1800/1900MHz
3G WCDMA - 850/ 900/1900/2100MHz
4G FDD-LTE B1/B3/B7/B20 - 1800/2100/2600/800MHz
Wifi, Bluetooth, GPS, A-GPS, GLONASS & BEIDOU, g-sensor, proximity sensor, light sensor, magnetic field sensor
OTG - USB on the go
OTA - Firmware update over the air feature
Off-Screen gestures / fingerprint scanner
Main camera: 13 MP output, autofocus, LED flash, F2.8
Front camera: 8MP output (5MP real?), LED flash, F2.8
2550mAh battery?
Dual Sim - Dual Standby
Weight: 170g / 8,5mm thick
Von hier: http://en.efox-shop.com/ulefone-be-touch-3gb-mtk6752-17ghz-octa-core-55-zoll-ips-ogs-fhd-bildschirm-android-44-4g-lte-sma-g-301638
Testbilder auf meinem Blog: http://colonelzap.blogspot.de/2015/06/ulefone-be-touch-review-mt6752-64-bit.html
