J
johndebur
Steht jetzt nicht da wie das handy heißen soll, wird auf jeden fall von Oppo hergestellt.
Ausgestattet mit nem kapazitiven touchscreen 3.5" WVGA
Android 1.5
5MP kamera
soll aber erst im 3.ten Quartal auf den Markt kommen.
Eventuell schon mal ein prima Weihnachtsgeschenk?
http://shanzhaiji.cn/mobile/20100112/15102.html
Android 1.5
5MP kamera
In order to maintain the competitiveness of foreign brands, OPPO's first Android smart phone will be equipped with 3.5-inch display, and supports multi-touch capacitance screen, and its resolution WVGA-level reached 480 × 800 pixels. In addition, the product is equipped with a 5 million pixel camera, 3.5mm headphone port as well as the provision of micro USB data cable port is equipped with WiFi capabilities, support micro SD card expansion.
3.5-inch WVGA 500 megapixel OPPO Smart Machine Exposure UI configuration parameters and the strong OPPO smartphone UI Jing Bao
In everyone's attention in the system version, this item is temporarily carrying the Android 1.5 version, network support for 2.75G's EDGE, but does not rule out the latter will be upgraded. As for the aircraft's launch is expected in the third quarter, in this hope OPPO side will intensify its schedule,
