J
johndebur
Der display ist ja schön groß, aber irgentwie sieht es auf den Bildern aus als würde es gleich auseinanderfallen.
kann mich auch täuschen. Soll so um die 1500 yuans kosten.
http://www.m8cool.com/article/view-113-19578.aspx
This cottage version of the Droid, and the original machine with the same tough exterior, 60x115.8x13.8 the body, also appear to be sufficient domineering.
The same sliding full keyboard design, layout and buttons are the same as the original machine. In addition, a 3.7-inch high-definition touch screen, a resolution of 800X480, which carry the WM6.5 operating system interface for Google also break out the tears ran.
This machine adopts Huawei Hass most high-end K3 533M CPU, GPS, WIFI, FM functions are ranging, 256M ROM and 256M RAM memory combinations, integrated configuration is already not low. According to sources, the aircraft may be priced around 1,500 yuan.
