Huawei Honor Band 4 Running Version für 20.84€
Gearvita
Huawei Honor Band 4 Smart Wristband Running Version
Gutschein: HNBand4R
Preis: 20.84€
Product Features
● Bluetooth Smart Connection
Based on Bluetooth technology with low power consumption and long-distance transmission, the connection distance is farther and more stable.
● Six-axis Sensor
Six-axis sensor with higher accuracy, is used to detect seven indicators data. Includes landing method, ground impact, valgus amplitude, swing angle, stride, step frequency, touchdown time. And it will offer you scientific interpretation and motion suggestions for running parameters. Improve running efficiency and reduce the risk of injury.
● Comes with a Shoe Buckle
You can wear this smartwatch on wrist, also the shoe buckle can help you wear it on your shoe lace. Suitable for more scenes.
● Sleep Monitor
Provides you with the quality of your sleep, helping you take steps to improve it.
● Exquisite Workmanship
Adopts injection moulding technology with its unique design, effectively prevents the Smartwatch from falling during strenuous exercise.
● 77mAh Battery Capacity
77mAh capacity with low consumption brings high performance and longer working. Standby time up to 20 days.
● 50m Waterproof
Withstands hand-washing or splashes water for daily use, but not available for bathing, sauna and diving.
● Wide Compatibility
Support Android system 4.4 version or above, iOS system 9.0 version or above.
● Lightweight and Skin-friendly
About 17g, ultralight, and the soft TPU band is comfortable and skin friendly, perfectly fit your wrist.
