HUAWEI CM33 Type-C Earphones für 13.25€
Gearvita
https://gearvita.com/huawei-cm33-type-c-earphones.html
Gutschein: HWCM33
Preis: 13.25€
Product Features
● Hi-Fi Quality Sound
Output sound with dynamic, deep bass and high resolution treble, ensuring that you listen to your favourite musics in Hi-Fi quality.
● Ergonomic Design
For improved comfort and performance, and allows you to wear it for long hours with great comfort.
● Integrated In-line Controls
Allow you to control your music without having to touch your phone. A simple press of the muti-function controls enables you to change your devices volume, play / pause and skip the tracks of your music.
● USB Type-C Connection
Makes it compatible with many smartphones and tablets.
● Plug and Play
Plug in and play with USB-C connection, quite simple and convenient.
● High-quality Material
Made of excellent materials, durable in use and built for the last, also , with unique and fashionable appearance.
