Asus Zenfone Max Pro M1 - 6" Display Snapd 636 ? 4GB Ram 5000mah Android One?
J
johndebur
Angeblich neues Asus handy
华硕ZenFone Max Pro M1渲染图曝光:搭载骁龙636 mydrivers
ASUS ZenFone Max Pro M1 Rendering Exposure: Equipped with Snapdragon 636
Following the ZenFone 5 series, Asustek is about to unveil another new model, the ZenFone Max Pro M1.
On April 23rd, the famous eruptor God Evleaks brought renderings of the Asus ZenFone Max Pro M1. As shown in the picture, the Asus ZenFone Max Pro M1 uses a 6.0-inch 18:9 full screen, and the back uses a three-stage design. The camera layout is similar to ZenFone 5 and supports fingerprint recognition.
In terms of configuration, the ASUS ZenFone Max Pro M1 is equipped with a Snapdragon 636 processor. The chip is based on a 14nm process process. The Kryo 260 architecture and eight cores are used. The CPU has a maximum clock speed of 1.8GHz and the GPU is Adreno 509 with 4GB of memory. , The battery capacity is 5000mAh, supports dual card dual standby.
It is worth mentioning that the ASUS ZenFone Max Pro M1 is equipped with a native Android system, which means that it may be an Android One smart phone.
s_9d4fadabe1284a81a353f415faa2c18d.jpg s_b317cb8491fd41ce9c837d1813aeb4a2.jpg
I
iieksi
Wenn es so rauskommt und der Preis vernünftig ist, ziemlich interessant :)
Von den Daten her jedenfalls, dem 18:9 Gedöns kann ich bis jetzt noch nix abgewinnen.
Prick
