10,10€ - WiFi Smart Plug inkl. 2x USB Alexa/Google Home
TomTop
Elias Wu von TOMTOP Firma
Link:
https://www.tomtop.com/p-s2976eu.html
Wieder mal ein Top Produkt für das Smarte Zuhause. Im Flash Sale, aber mit Coupon nochmal günstiger + Points können verwendet werden. Besonders hier sind die 2 USB Buchsen.
CouponCode: „D11S2976“
Versand ist kostenfrei, kein Zoll da unter Freibetrag, 10-20 Tage Lieferzeit.
Features:
  • *1*AC Outlet&2*USB Outlets Plug:With extra 2 USB outlets,enabling to charge your devices while using this smart plug.
  • *Phone APP Remote Control Control:You can check the socket and operate through the free APP,very convenient and practical.(Note:Support APP to control AC output/timing/countdown,etc,Not USB outlets)
  • *Time Schedule&Countdown:Turn on/off your appliances according to the time you set,you will have no worries about forgetting to turn off the lights,thus saving energy.
  • *Elegant Design:Small size will not take up too much space,fashionable shape adds decoration style for your room.
  • *Smart Voice Control:Compatible with Google Home & for Amazon Alexa IFTTT, you can use voice order to turn on/off the plug,releasing your hands,a super experience for you.
Kostet normalerweise 13,79€
