Umi X2 - MT6589 4,7" Full HD display (1080P) 12MP Kamera 2Gb Ram 1499 yuans
J
johndebur
Angeblich soll das handy am 25.5. offiziell zu kaufen sein.
Zuvor gibt es ein paar Tage an denen ein paar batches verkauft werden.
Morgen ( 15.5 ) gibt es 10000 Stück ( Google translate übersetzt 10000 mit 1 Million , bing übersetzt da korrekter )
am 16.5 gibt es 10000 Stück
am 17.5. auch 10000
und am 18.5 20000 Stück
wenn ich richtig verstehe gibt es von der 1GB Version 60% und der 2GB 40 %, oder was ist das "high / low with the number ratio of 6:4"
Die 2GB Variante wird 1499 yuans kosten, während die 1GB Version 1199 yuans kosten wird .
分四天抢购 优米X2今日正式发售 mtksj
Of the four-day rush to buy high quality rice X2 officially on sale today
Some time ago UMI quality rice Mobile announced that its high-profile quality rice X2 processor upgrade to the latest MT6589T (Turbo) version, and launched a low version, both versions will be on sale May 15. However, from the latest situation seems to all changes, quality rice phone official news shows, the original plan May 15 sale of 50,000 units will change the composition four days, from 15 to 18 days, every day at 10 am sale other snapped rules unchanged.
Along with the adjustment of the release date, the number of sale as well as the proportion of high and low with version change with open May 15, and the next few days to buy a specific number of high and low with the color ratio information is as follows:
May 15, 10:00 a million units open to buy (high / low with the number ratio of 6:4, color black and white 1:1) This article from MTK mobile phone network http://www.mtksj.com
May 16, 10:00 a million units open to buy (high / low coordination number ratio of 6:4, the color black and white 1:1)
May 17, 10:00 a million units open to buy (high / low coordination number ratio of 6:4, the color black and white 1:1)
20,000 units open at 10 o'clock on the May 18 purchase (high / low coordination number ratio of 6:4, color, black and white 1:1)
Other details the same as previously announced in the official, 2GB RAM high with version is priced at 1,499 yuan, 1G RAM low with version sells for 1,199 yuan, the number of each user the purchase of two, unified release date is May 25.
Quality rice X2
High quality rice X2 version of the distinction only memory specifications, high version with 2G RAM +32 G ROM combination with low version of the runtime memory 1GB the fuselage internal storage space to 16GB, support maximum 64G expansion, other Both exactly the same. The high quality rice X2, low version is equipped with a 5-inch IPS screen resolution of the current high level of FHD 1920 * 1080, second generation Corning Gorilla protection glass, touch screen to follow the mainstream the OGS full fitting process. This article from MTK mobile phone network http://www.mtksj.com
Quality rice X2
Equipped MT6589T quality rice X2 security Bunny V3 ran into 14525
Processor upgrade also further enhance the cost-effective high quality rice X2, the quality rice X2 is also the first to announce equipped MT6589T upgraded version of the model, the main frequency of the processor and GPU part of the upgrade, 1080P full HD screen experience will no doubt be more on layer, in addition to high quality rice X2 also has a 13 million pixel back-illuminated second generation of vice 2,000,000 main camera (F/2.0 aperture), comes standard with a capacity of 2500 mAh battery, body thickness of only 8.9 mm, and built-in a gyroscope, electronic compass sensor, support WCDMA + GSM dual card dual standby function. ROM part of the official commitment late there will be a series of excellent ROM support, and support a key Brush Brush Wizard.
As one of the few able to compete with the big Coke-generation mobile phone MTK6589 quad-core models, upgraded quality rice X2 has a higher price, which is also has many die-hard diehard and the first volume of 50000 .
nizeazz
sollte in der überschrift nicht 5 zoll stehen?
Die bringen auf den bildern das schwarze gerät so schön hin, aber auf reviews ist es nicht so der hit, sieht hinten nach sehr billigem plastik aus.
J
johndebur
eigentlich schon, kann das aber nicht ändern :) In der Liste ist es auf jeden Fall korrekt :)
J
johndebur
5 Seiten review auf PConline: Hat ne saubere ROM was auch auch nicht häufig ist :)
Commendable that the system's internal quality rice X2 is very clean, no built-in extra third-party applications are coupled Brush Wizard Good machine, ROM can have more choice.
mobile.pconline.com.cn/331/3311152.html
Übersetzung
Testfotos
Quad-core 5-inch 1080P screen quality rice price 1499 yuan X2 Review
[PConline evaluation] In recent days, the domestic four-core mobile phone is to get into the limelight, and today to review the evaluation room is a quad-core God-made machine, it is a high quality rice X2. Quality rice X2 features 5 Inch 1080P screen, powered by the mainstream quad-core processor configuration remarkable, following an up and observe what God Machine this made quad-core performance of it.
Hardware Configuration
Quality rice X2 parameters
CPU MT6589T 1.5GHz quad-core
RAM​
2GB
ROM​
32GB to 64GB of memory card expansion
Screen​
5.0 inches (fully fit) 1920x1080 resolution IPS​
Camera
13 million pixel back-illuminated Generation 2 + megapixel front camera f/2.0 large aperture
Operating system
Android 4.2.1
Inductor Light / distance / gravity / axis gyroscope
Type of SIM card Dual card slots standard SIM card
Dimensions​
141x70x8.9mm
Battery​
2500mAh​
Network standard WCDMA / GSM dual mode dual standby
Review Summary
优米X2评测
Quality rice UMI X2 picture evaluation forum quotes
From the above performance, quality rice X2 as a domestic four-core mobile phone, at the same price of the quad-core phone, to find out the 5-inch 1080P screen, quad-core phone really is not easy, a lot can be said to defeat the same type of competitor, and accurate positioning, that can catch the hearts of many consumers, be optimized if the publicity, I believe that quality rice X2 is a promising 5-inch 1080P screen, quad-core models.
3311152_23422.jpg3311152_IMG_5834_thumb.jpg3311152_IMG_5837_thumb.jpg3311152_IMG_5840_thumb.jpg3311152_IMG_5844_thumb.jpg3311152_IMG_5847_thumb.jpg3311152_IMG_5850_thumb.jpg3311152_IMG_5851_thumb.jpg3311152_IMG_5853_thumb.jpg3311152_IMG_5855_thumb.jpg3311152_IMG_5865_thumb.jpg3311152_jt11.jpg3311152_jt12.jpg3311152_jt13.jpg3311152_jt01.jpg3311152_jt02.jpg
ElaO
Ich habs in der engsten Wahl, überlege noch ob die 16GB oder 32GB Variante.
Cases finden sich nur sehr schwer, eher gar nicht.........
AW: Umi X2 - MT6589 4,7" Full HD display (1080P) 12MP Kamera 2Gb Ram 1499 yuans
Das 32GB halte ich für überteuert und $350 USD werde ich nicht in "garantielosen Chinesen" investieren, den noch keiner in der Hand hatte.
Am Donnerstag chate ich mit Mixe. Mal sehen, was ich raus bekomme.
Stückzahlen stehen schon mal nicht dran.
http://www.mixeshop.com/Supply-umi-mobile-phone_c364
ElaO
mmmh.........
Ich hab so gerechnet:
Umi X2 = 186,96 Euro
Euxep = 34,20 Euro
__________________
insgesamt 221,16 Euro
DHL Express = 22,01 Euro
Zoll = 39,70
________________
insgesamt 248,67 Euro
Macht eine Ersparnis mit dem Euxep Versand von 27,51 Euro!
Ist das verkehrt so?
Nein, nur die halbe Wahrheit. Du hast die Selbsterklärung det EUSt vergessen:(
Kann mal einer das Top Thema richtig stellen.
5,0"!
OT begin
Der Gesetzgeber verlangt von Dir bei einem Kauf ausserhalb der EU das Abführen einer korrekten EUSt. Entscheidend ist, wo Du bezahlst. Den GG interessiert nicht wie es zu Dir gelangt.:)
OT end
ElaO
Da das ja bei der DHL Einfuhr auch dazu kommt, ist EUXEP günstiger .............................:dirol:
JensK
Ela0, falls du mit Paypal in US$ bezahlst, musst du noch ca. 3% Umtauschgebuehr aufaddieren.
Kannst du das nochmal erklaeren ? Dies wuerde ja, rein hypothetisch, heissen, dass wenn ich wie beim zopomobileshop in China kaufe, nachtraeglich Einfuhrumsatzsteuer an den deutschen Staat zu zahlen haette, auch wenn die Auslieferung von Italien aus stattfindet und bei der Einfuhr von China nach Italien schon entsprechende Steuern durch den Lieferanten abgefuehrt worden waeren.
Bin absolut kein Experte, aber das halte ich fuer nicht richtig. Soweit ich das bisher verstanden habe, werden Waren beim Eintritt in die EU Zoll und Steuer unterzogen.
OT begin
Entscheident bist Du. Bezahlst Du in China, bist Du der Importeur. Den Gestzgeber interessiert nicht, auf welchen Weg es zu Dir kommt!
Auch EUEXP ist kein sicherer Hafen.
Bei dieser Diskussion solltet Ihr nicht vergessen, dass Ihr hier nicht in einem Hinterstübchen sitzt.
OT end
