MonaSteve
habe Probleme bzw. weiß nicht wie ich die mittlerweile zwei updates vom dg2014 auf mein phone bekomme.
Was ist bisher gemacht habe:
Habe mir hier http://www.doogee.cc/en/gb/xiazai.asp?Page=2 beide updates auf meinen PC geladen und unzippt. Meine emmc-Scatterdatei eingefügt und nach dieser Vorlage versucht auf mein phone zu flashen.
[How To] Flash ROM with SP Flash Tool On MTK6595, MTK6592, MTK6589, MTK6572, MTK6582
Flash ROM with SP Flash Tool On MT6595, MT6592, MT6589, MT6572, MT6582, MT6577
If you’d like to know how to flash a ROM on MT6595, MT6592, MT6589, MT6572, MT6582, MT6577, you’re on the right post. Normally we refer people to a rooting post, which includes this information, as the procedure is mostly the same. But for the sake of simplicity, we’ll write a stand-alone tutorial.
Note, if you don’t have access to a backup, create one first -
Remember, we ARE NOT responsible for any hell that happens to your phone. You take any and all responsibility for messing with your phone.
What you’ll need:
•MTK / MediaTek based smartphone
•USB Data Cable
•USB ADB VCOM drivers
•SP Flash Tool
•MTK Droid Tools (if scatter not included with ROM)
What to do:
•Step 1 – Install the PDANet USB ADB VCOM drivers -
•Step 2 – Download, extract, and run the latest version of SP Flash Tools
•Step 3 – Check to see if a scatter file exists. Look in the firmware / ROM’s folder. You should see a file that looks similar to ‘MT6582_Android_scatter_EMMC.txt’. If you don’t see the scatter file, you need to create one with MTK Droid Tools. After you’ve created the scatter, place it in the same folder as the firmware / ROM you intend to flash.
•Step 4 – Select ‘scatter-loading’ from upper-right of SP Flash Tools. Navigate to the ROM / Firmware’s directory and you should see a file that looks something like MT6582_Android_scatter_EMMC.txt. Select this and you should then see a checklist of different parts of the ROM load in the bottom portion of SP Flash Tools.
•Step 5 – Deselect ‘preloader’ in the checklist. If you don’t want the firmware / ROM to mess with your current partitioning, deselect EBR1 and EBR2 as well. NOTE: If you’re sure you have the correct firmware for your phone, you can leave Preloader selected.
•Step 6 – Make sure the phone is disconnected from USB and powered off. Select ‘download’ from the top of SP Flash Tools. NOTE: If all portions of the firmware are checked, then you can select ‘Firmware Upgrade’. If you have problems with ‘Firmware Upgrade’ or vice versa, you can try the other one.
•Step 7 – Connect USB cable to phone and watch the pretty colors fly
Ich habe die Variante mit und ohne Preloader als download und firmware upgrade versucht. (Mit Preloader s. Anhang)
Bei der Variante download ohne Preloader ist mir aufgefallen, dass der "lila Balken" nicht erscheint.
Trotz alledem, ich kann machen was ich will, phone hängt sich nach logo auf.
In den Recovery-Modus gelange ich nicht. Da liegt dann nur ein Android-Männchen mit roten Ausrufezeichen auf dem Rücken.
Ich weiß nicht was ich falsch mache. Vlt. kann mir jemand sagen, was ich falsch mache und wie ich die updates auf's phone bekomme.
What you’ll need:
•USB Data Cable
•SP Flash Tool
What to do:
