Hiphone 4 688 MT6235B Firmware
Dieses Thema im Forum "General Discussions" wurde erstellt von KLiFF, 30. November 2010.
  1. KLiFF
    KLiFF New Member
    13. April 2008
    p168+
  2. Rumpelstilzchen
    Online
    21. Juli 2009
    Nexus 5
    You can not download the full image.
    Not with FlashTool and also not with Spiderman.
    I will check the firmware and give you a flashable version :)
    Edit: Here now is the flashable Version: click
    And please note: your firmware ist not secure :(
    Flashing on your own risk.
    Do it as in the video for NAND-Flash (the download): click
    First flash all ROMs with the scatter-loading "scat_MT6235_Rumpelstilzchen.txt"
    After that flash the ROM with scatter-loading "scat_txt_SEC.txt"
    Now the phone should work :)
  3. KLiFF
    KLiFF New Member
    13. April 2008
    p168+
    thanks,
    i try to upgrade/change the firmware, because the wifi is not work, try to enable wifi= always search.. search... search.... and nothing found wifi network.
    i think change/upgrade the firmware, solve the wifi connect.
  4. Rumpelstilzchen
    Online
    21. Juli 2009
    Nexus 5
    But please be careful !!!
    First make a readback of your original firmware.
    That one you postet is not secure. It is not 100% sure that it will run.
  5. KLiFF
    KLiFF New Member
    13. April 2008
    p168+
    ok, waht is this?: scat_txt_SEC.txt
    what is page file?: 100-110MB
    and why write only 30MB (rom,third,secondary), the full flash is 128MB (132mb).
  6. Rumpelstilzchen
    Online
    21. Juli 2009
    Nexus 5
    Because you can not handle a NAND-flash as full flash.
    128MB includs also the custom-memory. Has nothing to do with the firmware.
    The scat_txt_SEC.txt is a scatter-loading file to correct the secret-zone.
    Because that firmware is not save.
    I have no experience till now with that option.
    So only flash the new one if you got a correct readback of the original.
    Perhaps your phone will be dead.
    NAND flash ist always with some risk ;)
